Old 01-29-2013, 10:04 AM   #21
Greg Reimer 7376
Liked 719 Times in 220 Posts
Cool Re: T350 help
Best wishes to you and for the success of this project. That's why I gave up working on cars in a dealership a long time ago. One of these things on a warranty ticket could wast several days of your time, and for nothing.Every line mechanic's worst fear was a trans problem that eludes normal diagnosis and repair.
Old 01-29-2013, 09:35 PM   #22
Mark Faul
Liked 43 Times in 9 Posts
Thumbs up Re: T350 help
Got it fixed! Turns out the case had a very low spot by the transbrake solenoid/modulator valve area. Was over .010 low! He got it all flat and made the valve smoother and made sure the travel was exactly right between the passages. Apparently was passing fluid like crazy across that low spot. He usually doesn't miss anything, but this seemed extra crazy!
Thanks again for all the suggestions and ideas!!!! It all made sense, and did double check everything that was mentioned.
Mark
Mark Faul is offline   Reply With Quote
Old 01-30-2013, 09:05 PM   #23
Greg Reimer 7376
Cool Re: T350 help
Glad to hear it's alive and well! Thanks for the update.
Old 02-02-2013, 04:42 PM   #24
ken robinson
Liked 224 Times in 87 Posts
Default Re: T350 help
The stock case casting strikes again. Glade you got it fixed.
