#111 | |
Liked 2 Times in 2 Posts
Kris Rachford 69 Cobra 428CJ 4 Speed C/S 3032 |
#112 | |
Liked 32 Times in 9 Posts
Mark Madison 7995 |
#113 |
Liked 8 Times in 4 Posts
Since the strut rod swings in an arc as the suspension goes through its full travel from extended to compressed, would a solid fixture such as a heim or ball type bushing on one end of the strut rod cause the cars alignment to change throughout the swing of the lower control arm?
#114 | |
Jeff Lee 7494 D/S '70 AMX |
#115 |
Liked 26 Times in 13 Posts
I think I would want to see a metallurgical study of that fracture before I assumed that it was a shear and not tensile break. I don't want to be the one that finds out when one lets go.
![]() I don't know of any aftermarket strut rods that are advertised as being tougher than the OEM and are direct replacements. Opentracker has a unit that looks fairly stout that might ease my mind, for one... http://www.opentrackerracingproducts.com/strutrod/
Bill Harris ex 2172 STK ex 2272 S/S |
#116 |
Liked 327 Times in 121 Posts
Are the B and E body Chrysler cars suffering the same issues as the Fords.
#117 | |
Parts can have minute fractures for long periods of time before a "Montreal " size pothole causes total failure. Dye-checking strut rods may be in the future for those requiring their own and others safety.
Peter Ash 6100 STK Last edited by Peter Ash; 02-04-2013 at 10:10 PM. Reason: sp |
#118 |
Liked 23 Times in 7 Posts
This is the NHRA at it's worst! I would really like to see some response from them as to why this was done.
They allow aftermarket disc brakes that are a performance advantage over factory drums due to weight savings because they are much safer. I understand why they allow them and nobody disputes the importance of having adequate braking at high speeds with heavy cars. What's more important than high speed steering and braking in a race car? So considering that the strut rods and their bushings directly affect high speed steering/handling and braking, shouldn't they be held in the highest regard in terms of safety and the implementation of new rules? Especially when the modifications in question offer no performance advantages? My Belvedere at 3500 pounds going 130 mph (hoping ![]()
Marc Lapoint |
#119 |
Liked 64 Times in 11 Posts
I was told that if wheel stands are a problem, with safely controlling the movement with stock OEM rubber bushings & strut rods, wheelie bars are legal in stock....use 'em! Well anyone that has tried to hook a heavy high powered stocker on a 9" tire knows if the wheelie bars touch the ground the car's tire will unload. I can get away with riding the wheelie bars for 30' on my super stocker because it has a big fat tire.... 2 different animal's. If the majority here {poll results} are OK with aftermarket strut rods who is advising NHRA tech to not legalize after market strut rods in stock? After all it's OK to have after market strut rods on a SS/MA car and not for a A/SA ???? Where is the common sense?
#120 |
Exactly! I'm curious after looking at the entry list for Pomona and seeing all the brake strut rod cars that are pre entered, if they all are going to show up with rubber bushings, especially Calvert.
