#11 |
Cam F/X lifters. Have not personally run them but I looked at every option out there as I thought I was going Super Stock. My impression is they are the best roller lifter out there.
Jeff Lee 7494 D/S '70 AMX |
#12 |
Liked 126 Times in 20 Posts
Can't say about the Isky but the Crower has worked good for us. We use the .903 with no problems. Was told last season there was a heat treat problem with some different batches of lifters, but problem has been fixed.
Tim Worner SS 1747 |
#13 | |
Liked 18 Times in 10 Posts
Jesels and Morels seem to a great lifter and so far never had to send any back because of sizing issues. Here is a link on roundness issues with crower .903 http://www.yellowbullet.com/forum/sh...fter+roundness |
#14 |
Liked 307 Times in 103 Posts
If have lifter problems first thing to check is springs,probaly 8 out 10 times you are gonna find you have other problems causing your lifter problem,especially when quality lifters fail
Bearing failure,axle breakage,flat spots on wheel, broke studs/rock.ers,head coming off valve,burred/stretched keeper grooves,tips of valves marked like X or * stretched timing chains all are signs of valve float,not always but most of time from too weak spring pressure,from wore out spring,wrong spring or setup wrong to start with. Mike Taylor 3601 |
#15 |
Thank !everybody for your comments and advices.
#16 | |
Just what has worked for me. Mine has never been over 8500 in the lights.
Ed Wright 4156 SS/JA |
