Where does a feller find the numbers that go on the inside of the windows. For instance . Allen Wades super stock camaro has some awesome lookin vinyls.
You just run them mirror reverse. It's not that hard. What did you have in mind?
Chad Rhodes 2113 I/SA |
Chad I just like the looks of them I like the way his name is in a script and the numbers are not to big and bulky . wades numbers are just about the right idea size. Do you do the vinyls?? chad?
Liked 275 Times in 76 Posts
Michael Beard
Liked 112 Times in 31 Posts
Glen Demenge. Glen's sign dezine McGregor, Mn does some really nice ones. I believe his number is 218-426-4009.
Liked 129 Times in 59 Posts
X2 on Michael Beard. He did mine and I'm very happy with them!
Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
Liked 53 Times in 25 Posts
Steve Bell in NJ.
Dennis P Chapman 1904 STK NHRA National Record Holder Car Owner. |
Liked 165 Times in 51 Posts
Try this
nhranumbers.com This place will make full color printed vinyl numbers that mount on the inside of the glass. And they look COOL! no stacking 1 piece. Also offer chrome with color outline. Last edited by MEXJOE; 02-19-2013 at 11:45 AM. |
Liked 13 Times in 9 Posts
I specialize in full color printed vinyl, and those you can't do as inside application, as the adhesive side is solid grey. In order to do inside numbers, you need to use standard vinyl that the same color on the adhesive side as it is on the outside. To get that look, you'd cut two separate decals (backwards) and stack them. Seeing it through the glass gives it a little more of a painted look. I used to do them when I had my physical sign shop, but I no longer have a cutter in-house. I work with a partner to handle the actual printing and shipping. We keep so busy with the full color printed stuff that something like that is now considered 'special order'. You should be able to get it done at any standard local decal shop.
