Old 02-23-2013, 06:06 PM   #1
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
Default I want the best Olds wet sump oil pan option........
All you guys that race (wet sump) '70-'72 "A" bodies, (stock chassis and steering) with a small block......... Who's oil pan are you using, and what are you using for oil pan mods? I am looking for better oil control (under braking) in the pan.
I like this pans oil control but the capacity is a concern... https://www.cantonracingproducts.com...&category=1504
Old 02-23-2013, 10:24 PM   #2
Daran Summerton
Daran Summerton's Avatar
Liked 66 Times in 37 Posts
Default Re: I want the best Olds wet sump oil pan option........
I run a moroso pan with a melling pump and thats it!!! Good for only 750 passes put the $ somewhere else.
72 cutlass
Daran Summerton is offline   Reply With Quote
Old 02-24-2013, 01:41 AM   #3
SSDiv6
Stef's. Oil Pan.
Old 02-24-2013, 11:35 PM   #4
Sam Murray
Sam Murray's Avatar
Liked 60 Times in 29 Posts
I use a stock 455 oil pan with an oil pump to main baffle for launching (stick car) and a crank scraper. Std volume speed pro pump. 6800 to 7200 in the lights depending on gearing. The only time I had low oil pressure braking was when I tried running 4 qts of oil. It dropped to 10lbs. Same setup on my 67 400 car. Like they were twins! Thought for sure the small block would be different.
Sam Murray
1616 STK
Sam Murray is offline   Reply With Quote
Old 02-25-2013, 09:26 AM   #5
Jim Kaekel
Liked 536 Times in 110 Posts
I've had some loss of oil pressure issues in the past as well. Another tip is using oil-restricted pushrods. Smith Bros. sells them.
Jim Kaekel 3836 STK
Old 02-28-2013, 06:09 AM   #6
rallye bob
rallye bob's Avatar
Stef's. Oil Pan.
Can't get Stef's to answer emails (picture request for insides of part # 1471)...
Old 02-28-2013, 09:08 AM   #7
Jim Kaekel
Pretty typical, unfortunately. I would guess close to 50% are not very good about answering e-mails from their web site. Concerning the pan, don't be concerned about advertised sump capacity, 6 qts. is plenty. I would get a pan that is as deep as possible, yet without worrying about bottoming out. It's not about increasing capacity, it's about lowering the sump away from the rotating assembly. My .02.
Jim Kaekel 3836 STK
Old 02-28-2013, 10:01 AM   #8
SSDiv6
Hope this helps!
Old 02-28-2013, 07:12 PM   #9
rallye bob
rallye bob's Avatar
Hope this helps!
Thanks... What part# is this pan?
Old 02-28-2013, 08:20 PM   #10
FED 387
Liked 335 Times in 182 Posts
Bob ---sent u a PM
