Old 02-25-2013, 06:03 PM   #11
chlngr73
Default Re: Record Setting time in Baytown?
Originally Posted by Brett C View Post
Mr. Jeff,
It appears everyone must be too busy to answer due to getting there record run stuff ready!!!
Brett Candies
4192 Stock/SS
Hey, I think ya'll should drag that COPO out and set the CC record at say about 9.20 something, yea that should work! See ya'll there, have a safe trip.
David Buckner 4772
chlngr73 is offline   Reply With Quote
Old 02-26-2013, 09:49 AM   #12
Jeff Teuton
Liked 325 Times in 50 Posts
Well, it's getting better, low Friday 38, high 60 bright sunshine, 37 or Sat, high 60, need to set a record, start driving now for all you northern folks. Hell, I bet a bolt hole or a no bolt hole hemi SS/AH could set a record here.
Jeff Teuton 4022 STK
Old 02-26-2013, 11:28 PM   #13
Brett C
Liked 1,074 Times in 227 Posts
I guess that means that we'll see a stable of those Southland Mopars all apart this weekend!
Old 02-27-2013, 10:03 AM   #14
Jeff Teuton
No, I can't run 10.39 in E like the Findel's can in Minnesota. They got the record. I can't get there. Maybe if I move some bolt holes though. Hmmmmmm Correction: James Findel holds the E/SA at 10.58 and Andrew Hill holds the D/SA record at 10.39; both old cars. Hmmmmmm something amis here. Those combos need hp. F/SA is at a minimum though and I can probably run the 11.35 minimum cause of the good air. With the bolt holes removed. I bet if Andrew Hill took the bolt holes out, he could run 9.99 in D/SA.
Old 02-27-2013, 11:45 AM   #15
Andrew Hill
Andrew Hill's Avatar
Liked 174 Times in 39 Posts
All the bolt holes are already gone, everything's just held in place with superglue.
3207 D/SA, C/ED
Andrew Hill is offline   Reply With Quote
Old 02-27-2013, 01:39 PM   #16
Ed Wright
Ed Wright's Avatar
Just hook up the other two barrels, Jeff. LOL!
Ed Wright 4156 SS/JA
Old 02-27-2013, 10:07 PM   #17
Jeff Teuton
The bolt holes on my heads are hollow, and the air is routed into the throttle body after it gets a dose of blue bottle.
Old 02-28-2013, 04:41 AM   #18
Andrew Hill
I thought the beer was by the can, not the bottle?
3207 D/SA, C/ED
Old 02-28-2013, 08:49 AM   #19
Jeff Teuton
I don't share my beer, not even with my faithful motor Lucky. Today in Baytown, 41 degrees, 30.23 R Barometer, 37 Dew Point, Sunny, Tomorrow Better. Andrew, son, blue bottle does not refer to beer bottle. I worry about you.
Old 03-01-2013, 12:28 PM   #20
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
So just how good was it?
1320go had it at -900ft - I doubt that
Ron
