Liked 1,604 Times in 583 Posts
How soon we may see this new Chevy engine in the SS Modified ranks???
http://www.sae.org/images/enewslette...ain/03_455.jpg http://www.sae.org/automag/technewsl...ertrain/03.htm |
Liked 5 Times in 3 Posts
Try and get your hands on one, it will be a while!
Liked 132 Times in 30 Posts
Sure looks like the bogus Toyota package, at least from the outside. Toyota's nothing more than homogenized Ford/Yates and SBC SB2 engineering. This new SBC looks alot like a Ford 385 series combined with 351C. Rumor has it the NASCAR master plan is to have generic V8 design for all manufactures. And like the bodies, the only separation would be the nameplate.
My question is, what does the future hold for traditional OHV engines? Or parts availability for that matter? Ford's push has gone to the modular OHC motors, judging by their current parts program. |
Liked 1,880 Times in 422 Posts
I looked at the Toyota engine, the block looks a lot more like a Chrysler NASCAR block than anything Ford. The heads do somewhat resemble an SB 2 setup.
I looked at an R07, it does not remind me of a Cleveland or a 385 BBF either one, except for the front mount distributor. Looks a lot more LSX/shrunken Rat than anything else. Allowed to evolve, they'll all look a lot alike, because they're designed for the same purpose, under the same rules.
Alan Roehrich 212A G/S |
Liked 81 Times in 35 Posts
must retain OEM bore spacing. What does that mean? Pro Stock does not have OEM bore spacing but they run those engines in comp.
Greg |
#6 | |
It remains to be seen whether the R07 makes substantially more power, or is just more durable and easier to work with, and has a small HP increase. I think if it had a great deal more HP potential, and NASCAR could see it, they'd have never let it in. Remember how much trouble GM had getting the SB 2 and SB 2.2 stuff in? Of course, I'm not real convinced that the current bunch running NASCAR is exactly the sharpest knife in the drawer when it comes to doing anything but screwing up, and trying to squeeze another dollar out of their gullible spectators.
#7 | |
Now, if Chevy moved the crank thrust bearing to the middle, then I'd say they were copying Ford.
Rich Hedden 6011 BF/S |
Hell if you can get one, just put it in your car. Bore spacing smore spacing, all ya need is a buddy in tech and he'll let you slide and then when someone figures it out and bitches or theatens to tear you down, NHRA will just make a rule change legalizing what use to be illegal and screw everyone with a legal engine right up their ***'es to the tune of tens of thousands of dollars because now you can't sell that obsolete piece and you absolutely have to have the new piece to be remotely competitive.. way to go, my beloved NHRA... So run whatever you want, that silly rulebook is merely a suggestion.
