Liked 7 Times in 6 Posts
Is there a hold down clamp made that will put pressure on the center of the distributor base where it meets the gasket? All the ones I see do not get close to the center. Mine leaks vacuum at the base of the distributor on the passenger side. I'd rather not have to make one if I don't have to.
I put some RTV around the top of the adjustable collar and it helped. I'm pulling close to 8 inches now.
Liked 56 Times in 27 Posts
Ron,
If it starts leaking again , use only the Ultra - Permatex !!! It stops exhaust , oil & air leaks for good, much better than the regular stuff ...
Dave Ribeiro 1033 STK Last edited by Dave Ribeiro; 03-18-2013 at 05:22 PM. |
Liked 129 Times in 59 Posts
Ron, Here's the one I'm going to try -
Made by Dewzen, who sponsor Danny Waters Jr. ![]() http://www.shop.dewzen.com/Distribut...m1plqscsfapp05 I've never been happy with the older style stamped-metal clamp which seems to load the distributor sideways instead of tightening it down. Lew
Lew Silverman #2070 "The Wagon Master" N/SA |
drill & tap the block for another clamp on the other side.
Jeff Lee 7494 D/S '70 AMX |
Liked 10 Times in 6 Posts
I hope you find a solution,Ron. But I can't resist. After just dealing with a rear end cover sealed up with it, use some Right Stuff sealer on it. You won't even need a clamp! LOL.
Liked 888 Times in 239 Posts
The MSD 7905 hold down clamp is the strongest Chevy type clamp I've found.
It's made for holding magneto's which are notoriously difficult to keep from moving. I used to silicone the base gasket, but I've since machined an O-ring groove in the collar and it works great, no vacuume leaks and it's a lot easier to phase the distributer.
Thanks for all the replies, you guys are the best.
Dave, I used Ultra black. I just called it RTV because I'm a slow typist. Lew, If I knew that clamp was deep enough to pressure the center of the collar, I'd buy it. Jeff, I thought about putting another clamp on it, but I'm looking for an easy way out first. Dana, My tube of Right Stuff was like a brick. been to long I guess. Tom, I see that the 7905 uses a stud. This is leaking between the OD of the distributor housing and the ID of the collar and maybe some where the split is in the collar. Last edited by Ron Gusack; 03-18-2013 at 09:18 PM. Reason: typo |
Tom has the best answers.
Ed Wright 4156 SS/JA |
#10 | |
