Old 03-22-2013, 09:31 PM   #1
Joe DeMarzo
Liked 113 Times in 9 Posts
Default 2 barrel analysis question
How does the Chevy 350 " 70 2 barrel at 1686 X 1375 compare to the "72 2 barrel at 1686 X 1260?
Is there a significant difference?
How about how much slower is the 2B to a 4B?
Thanks.
Joe DeMarzo 1317 STK
Old 03-23-2013, 07:05 AM   #2
Lee Valentine
Liked 319 Times in 68 Posts
Default Re: 2 barrel analysis question
Joe, stick with the Q- Jet mileage won't be that much better with the 2 bbl. See you soon spring is coming I promise. Lee.
Lee Valentine 1661 STK
Old 03-23-2013, 07:40 AM   #3
danny waters sr
danny waters sr's Avatar
Thumbs down Re: 2 barrel analysis question
Don't know about the 350 , but my 283 was a turtle with a 2bbl...
Everyone told me it would ,but i had to see for myself..........
One day wasted with that project.............
Old 03-23-2013, 08:13 AM   #4
Billy Nees
Liked 7,773 Times in 1,742 Posts
Joe, there's a pretty big difference between the 2bbl that NHRA "accepts" on the 70 and the 71-72 2bbl. There's also major differences in the 70 and 72 engines if that's what you're looking at.
Give or take about a tenth one way or the other, you'll slow down a second.
Danny, the 2bbl that you had to use on the 283 is a small base 2g(same as my 307) and they're pretty horrible mainly because the top of the carb is so restricted. The 350s used a wide base 2g. There's one 283 stick Chevy II that did set a record with one though!
Billy Nees 1188 STK, SS
Old 03-23-2013, 04:47 PM   #5
Tony Curcio
Tony Curcio's Avatar
Liked 4 Times in 1 Post
I have two experiences with the "big" two barrel.
In 2004 we compared Q-Jet vs 2 bbl on our 255-350 that was set up for IHRA pure stock at the time. It was a stick shift, with the mandated stock valve spring pressure and stock duration cam. The 2 bbl slowed it about .55 and it was further under the index, by about .15. We didn't need a rev limiter for either combo, it couldn't spin high enough to hurt itself.
Two years later, same car with a modern NHRA stocker engine and an automatic. This time the Q-Jet was further under the index by about .30 or more. As the difference between H/SA and M/SA is .70, this must mean it slowed 1.00 that day, although in my mind it was worse.
The 2 bbl was going through the traps at 5700, the 4 bbl at around 7000+. Changing the gears and converter probably would have helped, but we decided not to pursue it any farther.
Tony Curcio 1860 STK
Tony Curcio is offline   Reply With Quote
Old 03-23-2013, 05:24 PM   #6
Lee Valentine
I really think you guys are missing the point, Joe went from a big block to a small block then he read the post on cost per run and says to himself I have to go 2 bbl. I'll save on race gas. I'll be Angelo agrees with me.
Old 03-23-2013, 06:20 PM   #7
Joe DeMarzo
Lee you are killing me.... I am laughing hard.
Thanks for the analysis.
So it would be a bad move I am guessing in '72 350/200.
Old 03-23-2013, 06:28 PM   #8
James Perrone
Liked 1,829 Times in 427 Posts
Lee you think of everything...lol...
james perrone 1290 STK
Old 03-23-2013, 06:44 PM   #9
Dennis P Chapman
Liked 53 Times in 25 Posts
Joe.......Back away from the car seat down have a cigar the snow will go away.
Dennis P Chapman 1904 STK
Old 03-23-2013, 06:58 PM   #10
Steve Calabro
Steve Calabro's Avatar
Liked 43 Times in 12 Posts
Send a message via AIM to Steve Calabro
Must be hanging out with Joe Zoom to much! At least Zoom has an enclosed trailer! LOL
Steve Calabro 1199 STK, SS
Steve Calabro is offline   Reply With Quote
