Liked 14 Times in 11 Posts
My buddy has a 1967 Barracuda Noch with 360/4 speed/8-3/4 w/4:10's
motor has 11:50 to 1 compression Edelbrock heads, air-gap intake and Holley 750 carb. ITT headers and exhaust, Cal-tracks with with Chyrsler spings at this point. Car weights about 3500 with driver. On dyno car makes 380 HP to rear tires. On MT street drag radials car with 1/8th mile 8.0's at about 94 MPH. tires are 275/60/15 run at 15-16 pounds. Called MT tire rep and he says MT street radials will not work with a stick car. So what brand, size drag slick do the stick racers recommend?? Open to opinions and comments
Phil Saran Parker, Colorado |
M/T 3056st designed for stick cars
Bill Belden Retired Stock Eliminator [emailSTK1100@comcast.net[/email] |
Definately 3056st MT. I would ask for the shortest tire in that size. The rollout can vary. Try to get something as short as possible. They can vary, but the tire vendor can check their stock for a smaller rollout set.
James Schaechter 3163 STK |
Liked 25 Times in 9 Posts
X2 for m/t`s
Liked 10,965 Times in 2,260 Posts
and put a Dana 60 in it. It will break a 8.75
Liked 137 Times in 46 Posts
What's special about the M/T 3056? How's it compare to a Hoosier 30x9 bias? Is the D07 the harder compound? Why would you want the shorter/less roll out tire? That goes against the more roll out the more conatact patch rule of thought? Sorry for the thread highjack! But I've been pondering same question.
The M/T's they are talking about have a stiff sidewall. I do not know how they compare to the Hossiers you mention.
They are suggesting a short roll-out because of the 4.10 gears.
Jeff Lee 7494 D/S '70 AMX |
Thanks for the information & feedback.
He is also building another 67 Noch, stroked 318 with a Pro Charger 5 speed stick and a Dana, Oh and full roll cage. He has a 1968 Barracuda Convertable Red/white nice body and interior, no motor or trans a roller for sale.
Liked 85 Times in 22 Posts
Has anyone tried the ST with an automatic?
