#21 |
Last time I had a car with that Petronix in it it ran pretty much as you are describing. It was in the car when I bought it. I went to auto zone, paid about $55 for a rebuilt single-point distributor and the AMX instantly ran perfect. Also picked up about 800 RPM.
Pull one plug wire at a time, ground it and see if you have spark out of all 8.
Jeff Lee 7494 D/S '70 AMX |
#22 |
i will give it a try Jeff.thanks...with the timing light hooked up ,timing mark it is steady for about 5 or 10 seconds them its instantly jumps about 20 degrees.starting to make altittle more sense.
#23 | |
Liked 109 Times in 44 Posts
Scott McIntyre-Cornville-retirement at last! 2015 Chevy SS. LS3/ 6 spd Stick-Wolf in sheeps clothing! |
#24 |
Liked 348 Times in 152 Posts
Chris - try swapping distributors and see if the problem goes away
Phil Molski PMR Performance S/C 1623 |
#25 |
changing distributors this weekend will let you guys know what happen...
#26 |
Liked 1,946 Times in 587 Posts
I have used the Pertronics conversion for years on my boat. It has worked perfect. I doubt that is your problem. Google the wiring for your unit online. I cant rember but I think you have to eliminate the ballast resistor. If the ballast resistor is still in the system that could be causing some issue. Also some ignitions used a resistor wire. Run new wiring to the coil and pertronics unit.
Mike Pearson 2485 SS |
#27 |
Liked 308 Times in 103 Posts
The way you say your timing is jumping around,it sounds like ignition control/box problem.
I have used alot of pertronix on restoration projects have'nt had any problems,I use ignitor 3 has protection circuit and built in adjustable rev limiter,pertronix tech line has always been helpful when I have called,oddball installations, I would probaly give them a call. I keep a hei w/wires so I can test and elimnate whole ign. system@ one time then have hei setup for msd so can determine box or dist. Don't take for granted that any part can't be or go bad. Mike Taylor 3601 Last edited by Mike Taylor 3601; 04-11-2013 at 08:41 AM. |
#28 |
Liked 54 Times in 27 Posts
Definitely check out the ignition as noted above. As a last resort, the carb to intake, or intake to head gaskets could be leaking vacuum.
#29 |
hope to change out distributor tommorrow...changed the advance springs in the current distributor from light to medium to heavy.....light is just simply to light and a great deal of difficulty cranking.heavy is ok ,but slow gettin to the desired timing mark from the dyno tuning ,tried the medium spring ,but when timing mark was set at the 40 degrees under a load,the intial timing at idle was just too low and the car ran crappy...hopefully the distributor change wiil do the trick..the 396 nova has 11;5;1 compression .via purestock drag rules... and a msd 6a.
#30 |
try eliminate msd box had one bad on customers car,had trouble starting and timing did weird stuff,was trying to get running could'nt twist dist to get running enough to even get light on it.
Mike taylo |
