Old 08-13-2007, 04:00 PM   #11
JDEMARZO
Wink Re: 12 bolt gear breaking problems....
Do not think you can use a street gear with a trans break, to much stress on the teeth, go right to a pro gear and it should not break. You could get by with a street gear if you were just foot braking.
Good luck
JDEMARZO is offline   Reply With Quote
Old 08-14-2007, 03:10 AM   #12
John Duzac
John Duzac's Avatar
Liked 83 Times in 20 Posts
Smile Re: 12 bolt gear breaking problems....
Ericsz: I run a stick shift Camaro with a 12 bolt rear end. I can tell you for sure if my 12 bolt stands up to the loads I put on it, a 12 bold will wokk for you too. 7800 rpm starting line launch and so far no trauble. Pro gear is the way to go!
John Duzac D/S 4448 STK
John Duzac is offline   Reply With Quote
Old 08-14-2007, 08:33 AM   #13
Don Fardie
Don Fardie's Avatar
Default Re: 12 bolt gear breaking problems....
Ericsz,
I know a lot of automatics are running Street gears and the RPM?s you are leaving at should be alright, but Pro Gears will take the most abuse because of the softness at which they are harden to. Setting the BL at .012 is too loose for new and .004 is way too tight for new. Try setting them at ..007 and make sure the pinion depth is set correctly to get the pattern favoring the front of the tooth from center. What type of Gear oil are you running? Red Line makes different Shock rated rear end lubes that have always worked great for me. I run a Stick car with Pro Gears (Richmond) and I had great success in setting my rear ends up this way, after a LONG RUN of breakage in trying to find the right set up.
Good Luck??..Don
Don Fardie 1582 F/S B/G
Don Fardie is offline   Reply With Quote
Old 08-14-2007, 08:59 AM   #14
ericsz
Thanks so much guys, I knew I get some real answers from you guys, I keep hearing people say welp its time for a 9 inch. You guys have proven differently which is why I asked you folks...Thanks a lot!
ericsz is offline   Reply With Quote
Old 08-14-2007, 09:39 AM   #15
SSDiv6
Are you using a solid spacer or a crush sleeve in the pinion? If you have a crush sleeve, switch to a solid spacer with shims.
Old 08-14-2007, 09:47 AM   #16
Jeff Niceswanger
Liked 1,034 Times in 368 Posts
Eric,we finally gave up and did put a nine inch in.But back when we ran a 5.57 gear we never broke any gears.It wasn't until we started running a 6.00 gear and the pinion got so small that every 50 runs or so it would bust one.We set them tight, loose, bought MW caps,T/A cover etc.... Alot of it has to do with weight.We know alot of folks with the lighter class cars that run a twelve bolt and punish the crap out of them and they don't have problems.But when you get over 3100 or 3200 pounds ( our car is @ 3255 in F) they are on the edge,especially with the steep ratios. Buy the way I have a 5 gallon pail of that Redline Shockproof 140w gear oil that never has been opened setting here collecting dust. Anybody give me 50 bucks ?
Old 08-14-2007, 09:57 AM   #17
ericsz
I am in fact using a Crush Sleeve, the car also has a Richmond Mini Spool in it.
Old 08-14-2007, 10:53 AM   #18
Mark Ruset
Mark Ruset's Avatar
Liked 43 Times in 29 Posts
Eric I've been running a 12 bolt 5:14 Richmond street gears for the past 3 years and have had no problems I run a 68 camaro in G automatic and launch about 2600 rpm. I feel the key to longevity with a 12 bolt is pinion depth. You ensure that both the ring and pinion are getting the most contact when you are dead on this, will make for long life.
Mark Ruset 2048 STK
Mark Ruset is offline   Reply With Quote
Old 08-14-2007, 01:23 PM   #19
SSDiv6
Get rid of the crush sleeve and use a spacer kit with shims. This will maintain the pinion depth. The shock everytime you drop the clutch will have an effect on the crush sleeve.
Old 08-14-2007, 02:57 PM   #20
JDEMARZO
I used a street gear with a 31 spline axle in a G/SA (3250 lbs) for 15 years with no breakage, same gear set. Leaving on the converter is different than leaving on a trans brake. I have a A/SA with a pro gear because all the other A/SA cars ripped the street gears out within 10 runs on a 2-step or foot braking not even a trans brake.
I really do no think you can use a street gear with a trans brake.... Too much stress to the gear set on the launch. If A/S (leaving @ 7000 plus ) and super stock cars using trans brakes are using a 12 bolt your combo should be fine with a pro-gear with the trans brake. Buying pro gears is lot cheaper than changing the rear to a 9 inch.
J.DeMarzo
