Liked 36 Times in 11 Posts
Did anyone have problems with Sunoco purple/standard or blue/supreme passing fuel check at Norwalk div.?
Liked 52 Times in 9 Posts
Yes Sir . $174 `s worth , not worth a dime . Out of sealed five gallon cans .
Liked 4 Times in 3 Posts
Not at Norwalk,but I have run Sunoco-Purple-110 Standard for 28 years and have never had any problems till the St Louis Nat.last year where the said it was borderline-on a nearly new drum ?????
Liked 979 Times in 197 Posts
Sunoco people say they have given NHRA new numbers to use,but they have not updated the charts yet.So who knows.Some racers are using blue,which is not that more expensive per drum.
Liked 282 Times in 103 Posts
There is nothing wrong with Sunoco race fuel.Seems every race the last year or so,they tell you it is bad or borderline bad.Hopefully Sunoco can fix this issue with NHRA soon.I believe the charts need to be "updated".
Liked 561 Times in 138 Posts
Is there any sunoco fuel that is equivalent to vp c-11 or c-12?
My Dealer got a letter from Sunoco , they do not care .
What could possibly be wrong with the fuel? Too much octane? Do you have to run ''track'' fuel? Or, can you come in with your own ''110 octane'', and pass?
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
Liked 160 Times in 51 Posts
Had problems out west here at the recent Div 6 divisional. 110 Purple checked "on the bottom" but came up 1 step up with no changes or fresh fuel added later in the day as the temps warmed. Always have had trouble at west coast divisional/nationals with Sunoco 110 whether from pump or barrel. "ITS FLAT" is the usual reply when checked. Lately got recommendations to switch to 112 as it checks better. Will let you know!
VP is NHRA's favorite for whatever reason, all others beware!
