Old 06-06-2013, 11:18 AM   #1
cad
cad's Avatar
Liked 93 Times in 52 Posts
Default AFCO front shock install 68 Camaro??
I am getting ready to order AFCO SA front shocks and DA rears for my 68 Camaro.
1. Do I need BNC if we are not doing wheel stands over 12", or should I use the money and order standard DAs over SAs?
2. I am looking for information on the install with stock control arms.
I have Calvert 90/10 fronts that are only 3 seasons old and had to open the shock mounting hole a little for those.
AFCO said that I will need to open the control arm more and then weld their ring in place. I also believe the upper stud is 9/16" and will need to open that hole, also.
Any installation advice from those with a Camaro/Nova?
Once I have done this, will I be SOL if I switch to another brand or want to put the Calverts back in?
Thanks
Clark
Old 06-06-2013, 12:01 PM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,967 Times in 595 Posts
Default Re: AFCO front shock install 68 Camaro??
I don't have the Afcos. I have santhuffs. I had to cut the bottom of the a arm out to the inside diameter of the spring then weld in clips on each side to bolt the shock to. I took the lower a arms off and jigged them in the drill press and used a hole saw to cut the opening. The control arm is made of real soft material so its easy to cut. I also had to move the mount point out to the outer side nearer the spindle to clear the adjusting knob at the bottom of the shock. Santhuff provided the bracket at the bottom of the shock that was real similar to the stock mount. The shocks work so good that I would never think about putting anything else back on. I think you will feel the same after you install the DA shocks on your car. I took about 8 hours to do the install on my car.
Mike Pearson 2485 SS
Old 06-06-2013, 01:08 PM   #3
njk53
We essentially have the same set up on our 71 Chevelle Wagon. We were using the Calvert 90/10 and went to a double adjustable AFCO.
The outer diameter of the AFCO Shock is larger than the Calvert. The lower control arms (LCA) will have to be modified to be able to get the shock between the spring if you go up through the bottom. The AFCO lower shock mount bolt pattern is wider than the stock bolt pattern. We had to machine the lower control arm to trim the stock shock mount holes away and welded the AFCO mounting ring that was provided with the new shocks in it's place. A bit of work but, I think in the long run worth it. If you modify the LCA's for the AFCO's the Calverts will not fit anymore unless you cobble up a mounting scheme to adapt back to the Calverts. As plentiful and cheap as they are, just get another set of LCA's and modify them. So if you want to go back to the Calverts for whatever reason, you can just switch the LCA's.
Nelson Kowal
Stock 345
Old 06-06-2013, 02:08 PM   #4
Ed Wright
Ed Wright's Avatar
I didn't find their BNC valving to help landings at all. Don't know anybody that did.
You might think about Santuffs. One of the best moves I made, switching from AFCOs to Santuff. No more bouncy landings. Had to run the AFCOs full tight both directions, and had to carry 65 lbs out in the nose to keep the front end down. Still bounced on landings.
Now that weight's back in the weight box, I just adjust the front shocks to keep it down. Can still go firmer each direction.
Ed Wright 4156 SS/JA
Old 06-07-2013, 10:52 AM   #5
Todd Hoven
Guest
Posts: n/a
X2
I was going to buy the Afco's , I must have talked to 5 people with Afco fronts with the same problem. Even people sent them back to be revalved, with no improvement.
I bought the Santuff's from Marty Reinhart with their mounting system, went right in, no bouncing .
Old 06-09-2013, 03:28 PM   #6
countrypuppy4865
countrypuppy4865's Avatar
Liked 229 Times in 71 Posts
Call randy mans with Fastshocks.com. I had a set of afcos that he redid that were bouncy and they land smooth as Santuffs.
Jimmy "Cooter" Hidalgo, Jr.
4865 E/SA '04 GTO
4865 SS/GA '99 Firebird
Old 06-09-2013, 03:37 PM   #7
Dyno
Dyno's Avatar
Liked 695 Times in 206 Posts
Randy's number at Fastshocks - 612-306-5387 He can custom order the shocks with the correct parts. Great service. He also sells and services Afco, Penske and now JRI.
Dyno is online now   Reply With Quote
Old 06-09-2013, 04:45 PM   #8
Buy Santuff's shocks. If you don't now, you'll wish you had later.
Old 06-10-2013, 10:11 AM   #9
njk53
Around how much do Santhuff's cost for a front shock for example for a say a 70 Chevelle?
Nelson Kowal
Stock 345
Old 06-10-2013, 10:52 AM   #10
cad
cad's Avatar
I'd love to be able to order the Santhuffs, but they are definitely not in the budget...and they are 4-8 weeks out according to Marty Rinehart.
I appreciate the recommendations. I have only heard that they are the best.
