#1 | |
Liked 1,580 Times in 582 Posts
This one is for Travis or any one who knows:
In the rule book, Section 5A - Stock Cars, Oil Pan, a paragraph in the section reads as follows: Quote:
In Division 7 Joel Larkin has done this to his first generation Firebird.
Liked 5 Times in 3 Posts
done what?
Joel removed the crossmember under his engine so he could pull his pan without removing the engine. He sliced out a section and then flanged everything so it could be bolted together.
So is it legal to buy a bolt in tubular cross member for a late f body.
Liked 39 Times in 9 Posts
I don't think a tubular crossmember would work in stock and probably not in super stock..
Ed Quay has a nice piece that I know is legal in super stock and I think is OK in stock. It is a modified factory piece and is not that expensive. If you send them your core it will reduce the price. edquay.com Reggie Winkles 4102 J/Stick |
Liked 52 Times in 17 Posts
Tommy,
Ya' need to stop getting all worked up over stupid issues !! The rules say it can be done, IF YOU WANT TOO !! ( Our old buddy, Skelly, got it done) I did it during the past winter so I can pull my pan anytime I WANT and it's not a bad deal. You'll never know, when at a track, a problem can bite ya. I still have the templates for the boxing if you need 'em. ( for a 4th. gen) CM tube across the cut out piece and it bolts in. When I did it, nothing moved !!!!!!!!!! B |
Liked 6 Times in 4 Posts
So can a mod. like this (only bolt in) be done in a '70 GM "A" body?
http://www.trzmotorsports.com/images/gbodyrack/ |
Bob, based on Bernie's comment, the modification shown in your pictures may be acceptable...with the exception of the rack & pinion.
