Liked 165 Times in 51 Posts
Any ideas on what may be happing?
I don't have a race pack. ![]() On the Playback tach 1st gear is real smooth to 6000 2nd gear it falls back an sits for a bout 1 second (in slow play back mode) then climbs slowly and "hops" a bit. to 6000 3rd it falls back to the same spot climbs slowly from 6300 on it starts" jumping & hopping" real bad. I don't know what this is the tach looks smooth when making the run the car doesn't miss or pop and runs a decent MPH 122 IN D/SA . Any help or ideas on what is causing this would help, thanks. Last edited by MEXJOE; 06-12-2013 at 11:07 PM. |
Liked 2,493 Times in 700 Posts
All our playback tachs are jerky when played back
in slow motion ...particularly in high gear as they are moving up more slowly. On the shifts they drop back momentarily to the converter stall speed as well have large ratio changes in our transmissions. Despite this they provide a lot of information to us. |
Liked 68 Times in 41 Posts
x2
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay Last edited by dartman; 06-13-2013 at 08:13 AM. |
Liked 4 Times in 3 Posts
Glen:Mines an older Autometer I bought used but it has always worked real well ! I would say check your ground---
Liked 136 Times in 49 Posts
You may want to look at getting a noise filter to cleanup the power and ground.
That and check the grounds. The majority of issues we find at work are ground related. Last edited by novassdude; 06-13-2013 at 08:16 PM. Reason: added |
