Old 06-17-2013, 08:16 AM   #1
Todd Hoven
Guest
Posts: n/a
Default Fogging an engine due to corrosive fuel
Hey guys, anybody that runs VP fuel knows its corrosive property's . Does anybody that runs it and pays attention to this problem have a solution for keeping this from happening? I know fogging helps, I've used marvel mystery oil for long term. What do you guys like to use? Does it help? Thanks in advance.
Old 06-17-2013, 08:55 AM   #2
Kenny Wigington
Kenny Wigington's Avatar
Liked 60 Times in 12 Posts
Default Re: Fogging an engine due to corrosive fuel
I don't. Ive been told it can cause pitting on valves, seats.etc. I doubt that adding MMO to your fuel, if thats what you're asking, would pass fuel check though.
2894 STK
Old 06-17-2013, 09:23 AM   #3
FED 387
Liked 333 Times in 180 Posts
marine/boat enging fogging products sprayed down the carb while cranking the engine over with the ignition OFF for about 20-30 seconds then remove each spark plug and spray into the cylinder and crank over a couple seconds replace spark plugs you should be good to go
Old 06-17-2013, 09:30 AM   #4
Ed Wright
Ed Wright's Avatar
I use MMO, with the engine idling I use a shampoo bottle with the little flip-up thing on the cap. Engine idling, dribble it into the idle air opening in the throttle body. Sucks it right in, continue until it smokes. Makes a good bit of fog next time it is started. The smell tips off what it is.
Ed Wright 4156 SS/JA
Old 06-17-2013, 10:28 AM   #5
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Also, as an added note, If you have an engine that has sat for a long time or outside in the trailer all winter, it's a good idea to fog the engine (we use an air /siphon gun) w/ MMO 24 - 48 hrs BEFORE trying to turn it over, also remove the plugs and spray / blow around in the chamber to coat everything. Turn it over by hand several times before using the starter and good to go.
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is offline   Reply With Quote
Old 06-17-2013, 03:21 PM   #6
Kegracing
Todd
Like others have already said, I have used MMO in my stocker, and my alky motor bracket - 10.90 cars for years. If storing for long periods of time (winter), would mix some MMO with a little gas, and actually put in cell (I pulled foam out first) and ran it thru pump, lines, to motor. I just put enough in to get it all the way thru lines to motor. When it smokes good, it is protected. I normally pulled plugs and put some WD-40 in cylinders also. Usually changed plugs after... not sure they needed it, just did it.
On alky car, I would spray thru carb after each race, both into vents and into mouth of carb. I tried some of the "fogging" sprays, but WD 40 seemed to do just as well for me. Stopped the "white death" from alky, and no corrosion issues seen.
Would just run some gas thru cell before going to track, and while warming up car, before first pass. Never had any fuel check issues with NHRA or IHRA doing this.
good luck,
Ken
Kegracing is offline   Reply With Quote
Old 06-17-2013, 06:38 PM   #7
Darrin Christen
Darrin Christen's Avatar
Originally Posted by ed wright View Post
i use mmm, with the engine idling i use a shampoo bottle with the little flip-up thing on the cap. Engine idling, dribble it into the idle air opening in the throttle body. Sucks it right in, continue until it smokes. Makes a good bit of fog next time it is started. The smell tips off what it is.
x2
4878 SS/GA 66CHEVY II
Darrin Christen is offline   Reply With Quote
Old 06-18-2013, 07:18 AM   #8
sg1586
This stuff is fantastic. Just spray it down the carb with it wide open and crank it over with the starter. It can be found at just about any marina or Advanced
auto has it also and even seen it at Wally world...I use it after I am done for the weekend of racing..
http://www.crcindustries.com/EI/prod....aspx?id=06072
sg1586 is offline   Reply With Quote
Old 06-18-2013, 02:35 PM   #9
Bill Belden
Bill Belden's Avatar
Todd, you have a pm
Bill Belden
Retired Stock Eliminator
[emailSTK1100@comcast.net[/email]
Bill Belden is offline   Reply With Quote
