Old 07-04-2013, 04:38 PM   #1
James Perrone
Liked 1,853 Times in 433 Posts
Default strange rear disc brakes .caliper mouting issue
Trying to put rear disc brakes on my nova .12 bolt rear with Moser axels.Disc brake kit is Strange...Notice this kit is for Strange axels .They must make another bracket or do I have to use there axels or c clip eliminator kit? Asking if anyone has run into this problem.I figure Strange is closed till next week. .Please help wanna race this weekend
james perrone 1290 STK
Old 07-04-2013, 05:41 PM   #2
astikhossw
astikhossw's Avatar
Liked 20 Times in 9 Posts
Default Re: strange rear disc brakes .caliper mouting issue
Is it the bracket to small for the axle flange.
astikhossw is offline   Reply With Quote
Old 07-04-2013, 05:45 PM   #3
Rick Leininger Jr.
James, is the issue that caliper is not centering up with the rotor?
The axle standout (distance from the rear end housing end to axle flange) may be different between the Strange and Moser axles, possibly causing misalignment.
Rick Leininger Jr. is offline   Reply With Quote
Old 07-05-2013, 12:51 AM   #4
Tylerdax
James call me when you can......I just went through the same thing on my 12 bolt with moser axles using moser C clip eliminators.........Your C clip eliminator is over in 1/8 to thick for strange brake assembly ......Call me and ill tell you how I fixed it
Ty Casey 817-709-5868
Tylerdax is offline   Reply With Quote
Old 07-05-2013, 08:22 AM   #5
James Perrone
tylerx you hit the nail on the head I will call
Old 07-05-2013, 09:31 AM   #6
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
james if you can't get ahold of tyler. all you need to do is have the aluminum brg. mount of the c clip eliminator machined down the thickness of the caliper mount, on the inner side.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 07-05-2013, 10:40 AM   #7
James Perrone
Thank you Mr Markow
