Old 07-17-2013, 10:43 AM   #1
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
Default 2013 NHRA Rule Updates
Question answered, Thanks!
Lew Silverman #2070
"The Wagon Master" N/SA
Old 07-17-2013, 11:00 AM   #2
Jeff Lee
Jeff Lee's Avatar
Default Re: 2013 NHRA Rule Updates
http://www.nhra.com/userfiles/file/2...%207-16-13.pdf
Jeff Lee 7494 D/S '70 AMX
Old 07-17-2013, 11:40 AM   #3
FED 387
Liked 333 Times in 180 Posts
Guys--having trouble accessing NHRA site for "ACCEPTABLE PRODUCTS"---who other than Lokar is on the list for the header tethers?? Thanx FED 387
Old 07-17-2013, 02:34 PM   #4
jmcarter
jmcarter's Avatar
Liked 3,184 Times in 973 Posts
I couldn't find any exhaust tethers listed, not even a section for it so no Lokar product there. Suspect they are getting ready to update the product listings.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 07-18-2013, 10:18 AM   #5
jmcarter
jmcarter's Avatar
NHRA updated the list today...here's the collector tether info..
Manufacturer
Part Number
Lokar
1400009
Lokar
1401009
Collector Tethers.com
Standard
Universal Kit
BTW, I couldn't find any such domain name searching Collector Tethers but perhaps its a start up business just getting set up...somebody on here will probably know about the product and update us
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 07-18-2013, 01:25 PM   #6
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
http://www.lokar.com/product-pgs/dra...tethering.html
Not mandatory until January 2014
Ron
Old 07-18-2013, 02:35 PM   #7
Chuck Garey
Liked 10 Times in 7 Posts
Question Re: 2013 NHRA Rule Updates
Am i reading the last page right?, I need a trans shield?
Chuck Garey is offline   Reply With Quote
Old 07-18-2013, 03:09 PM   #8
Jim Kaekel
Liked 535 Times in 110 Posts
That's only a quick reference chart. Only when it is added into the Stock Eliminator section is when it becomes mandatory.
Jim Kaekel 3836 STK
Old 07-18-2013, 04:18 PM   #9
Lew Silverman
Chuck,
The Quick Reference chart lists Section 20 (General Regulations) Paragraph 2:14 Transmissions
All vehicles running quicker than 10.99 seconds (*6.99) or faster than
135 mph (except some Stock and Super Stock classes as noted
under Class Requirements) and using an automatic transmission
must be equipped with a transmission shield meeting SFI Spec 4.1
and labeled accordingly. (“Blanket”-type shield, appropriately
labeled as meeting SFI Spec 4.1, permitted.) All non-blanket-type
shields must incorporate two (or one, per manufacturer’s
instructions) 3/4 x 1/8-inch straps that bolt to the shield on each
side and pass under the transmission pan, or transmission pan
must be labeled as meeting SFI Spec 4.1. Permitted in all classes
where an automatic transmission is used.
There is no specific mention of a Automatic "transmission shield" in the Stock Class rules, Section 10A.
Lew
Lew Silverman #2070
Old 07-18-2013, 06:42 PM   #10
FED 387
my experiennce in the past has been General regs override any of the class regulations UNLESS it specifically says something one way or the other!!! Better check to be sure ---The way I see it if your vehicle goes faster than X MPH or X ET you better have one
