Old 07-27-2013, 08:38 AM   #41
Ed Wright
Ed Wright's Avatar
Default Re: Which is faster carb or Fuel injection?
Originally Posted by SuperStock 1890 View Post
LT1 throttle body 783cfm at 28"
If I remember right it was 660 cfm at 20"
That is more than I was told. Dave Layer knows. Maybe he will see this and let us know.
Ed Wright 4156 SS/JA
Old 07-27-2013, 08:40 AM   #42
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Very good info right there that I had never heard before and it explains why an LT-1 can run
pretty fast as a SS'er or a Stocker...
Rich Biebel
S/C 1479
Stock 147R
Old 07-27-2013, 09:09 AM   #43
Ed Wright
Ed Wright's Avatar
But, if carbs are flowed at 12", that makes the LT1 throttle body smaller. Quadrants are 750 & 800 at 12", right? That throttle body won't be that at 12".
Old 07-27-2013, 04:11 PM   #44
rawhide
Liked 7 Times in 5 Posts
Holley four barrel carbs are flowed at 1 1/2" of mercury which is a little more than 20" of water. I don't know what others are tested at. The two barrel carbs from Holley are tested at 3" of mercury from what I have read.
Roland
rawhide is offline   Reply With Quote
Old 07-27-2013, 09:42 PM   #45
Ed Wright
Ed Wright's Avatar
Roland
That would make it 660 cfm, which about what I was told. Dave Layer told me my LT2 SS engine would be done about 8200 due to the throttle body restriction. It falls off a cliff about 8300 on the dyno. The 305" TPI cars have the same size, if I remember correctly (been a couple of years now.) Dave said the 305"s run right up to 8800/9000. Hope I remember the numbers correctly.
Old 07-27-2013, 11:51 PM   #46
Adger Smith
Liked 880 Times in 311 Posts
Joe ask the question: All things being equal in a stocker, lift, valve, piston, head, etc.. what would be faster a carb or fuel injection?
The question has not been answered, yet, and probably will never be because of those first 4 words in his question. I'll add 3 more words that will always keep them unequal... Wet & Dry flow.
Adger Smith (Former SS)
Old 07-28-2013, 07:40 AM   #47
Billy Nees
Liked 7,925 Times in 1,760 Posts
Originally Posted by Adger Smith View Post
Wet & Dry flow.
Finally, the magic words!
Billy Nees 1188 STK, SS
Old 07-28-2013, 08:42 AM   #48
Joe DeMarzo
Liked 123 Times in 11 Posts
Billy, I thought the magic words were "I love you or is it please and thank you"?
So the CFM of a FI and carb are currently not even if someone was to swap it out at the track? Also I presume the manifolds would not be an even swap????
When looking for an advantage in my original question how would you measure which would be faster or make more power theoretically? By CFM and or air volume?
By the by I have no idea what you FI guys are talking about with all that mojo but it sure is an education. Thank you!
Joe DeMarzo 1317 STK
Old 07-28-2013, 09:03 AM   #49
Jeff Teuton
Liked 325 Times in 50 Posts
I got a pretty good example. We ran Top Stock with a 360 w/ported Edlebrocks, an 850 good carb and it performed well. When the DP's came along, we added FI bungs on the manifold, changed from an QAF 850 to a 1000 CFM throttle body and we were now fuel injected. Same motor, same cam, same everything. It made about 10 or 15 less peak hp, which surprised us. Spoke to Wilson Manifolds. They said quite normal because the fuel starts atomizing in the carb, and the injector is down in the runner. Also said the total management with the FI system makes it better overall, but more technical. Then when NASCAR got FI, the injectors are in the top of the runner, which I think would be legal in NHRA SS. We will get around to trying that someday. My 2 cents
Jeff Teuton 4022 STK
Old 07-28-2013, 09:06 AM   #50
Adger Smith
Joe,
I know this doesn't answer you question in a direct manner, but......
Take a look at The Engine Masters Challenge rules for last few years.
When Wesley and I were doing the rules we made some slight differences between FI and Carbs to try to keep them as equal as we could. The differences are not all in the sizing, it is in the total induction package. Study that and you might be able to get a handle on what/where the difference really is.
Billy,
Another magic word to add to the discussion: Atomization
That word adresses the wet flow and the quality of the A/F mixture in the chamber before the combustion process. (touched on earlier)
Jeff, wow! I see we were typing at about the same time, but your got there first. (RT) Great minds must ...well
