Old 07-30-2013, 05:37 PM   #1
Ken Kopecky
Liked 273 Times in 56 Posts
Default Chassis dyno in New Jersey
I've been plagued with Ed Fernandez's evil twin gremlin (sorry Ed, I couldn't resist) since the beginning of the season and have tried everything that I can think of to track it down but no luck. I was wondering if anyone in the New Jersey area knows of a place that has a chassis dyno that I can put the car on to see if something can be learned. Some of the shops have closed so if someone can steer me in the right direction, I would really appreciate it.
Ken Kopecky
1454 E/SA
Ken Kopecky is offline   Reply With Quote
Old 07-30-2013, 05:38 PM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Chassis dyno in New Jersey
Julio at Cartek, Garwood NJ.
Ed Wright 4156 SS/JA
Old 07-30-2013, 07:47 PM   #3
Pistol Pete
Pistol Pete's Avatar
Liked 795 Times in 210 Posts
Profab in Whitehouse Station.
"Pistol" Pete Dutko
Old 07-30-2013, 08:38 PM   #4
Lee Valentine
Liked 319 Times in 68 Posts
Ken , Div. one super stock racer Jeff Roell Danbury Chassis Dyno Danbury, CT. Not that far for you. Really knows his stuff has helped a lot of racers.
Lee Valentine 1661 STK
Old 07-30-2013, 10:34 PM   #5
SGSST109E
Liked 126 Times in 61 Posts
Can Bill Trum here. Bobby Ida has a chassis dyno and he if right off Texas rd and rt9 in NJ
SGSST109E is offline   Reply With Quote
Old 07-31-2013, 09:18 AM   #6
Signman
Liked 269 Times in 99 Posts
Jeff at Danbury Chassis Dyno. Some top cars roll off his dyno.
Old 07-31-2013, 12:22 PM   #7
Lightbulb Re: Chassis dyno in New Jersey
Kenny - If your car was a Top Fuel / Funny / or a Pro Stock there would only be one fix to the situation that you've been chasing all year - they would do it and so should you - tear out the wiring and redo it all .Then you can go and race again ............
Old 07-31-2013, 12:34 PM   #8
Dennis P Chapman
Liked 53 Times in 25 Posts
Jack he already did it.
Dennis P Chapman 1904 STK
Old 07-31-2013, 12:57 PM   #9
Ken Kopecky
Hi Jack. As Dennis indicated, I redid the wiring, checked all grounds and connections, replaced the entire ignition and fuel systems, new distributor, tach, shift light, batteries, carb, master battery cutoff switch, and retested the MSD setup twice. Still didn't fix the problem. I also checked the cam lift at the vavle, valve lash and static compression in the engine. All checked fine.
Ken
Old 07-31-2013, 01:10 PM   #10
Ken
Kenny -You have to do more than check them - they must be replaced - all of them or you'll never know ...............
