Liked 71 Times in 23 Posts
Who makes a good 1" - 2" carb open plenum spacer? I am working on friends bracket car, don't know a lot about the motor. He bought this back halved s-10 and motor as a package. I do know its a 377 sbc .570 ish flat tappet cam. 270-280 @.50, aluminum heads that have no name on them. Nice open plenum Edelbrock intake, Holley 4150.
Not looking for any top secrets. Just want to buy a good carb spacer that works. Thanks Monte.
Monte Howard 3209 STK, 3208 SS |
Hvh makes a nice 4 hole I use a lot on dirt modified engines seems to average anywhere from 6-9 hp on the Dyno
Aaron Disinger |
Comp Cams makes a really nice one with vibration dampener built in. Great part, makes power, not cheap!
Jeff Lee 7494 D/S '70 AMX |
Liked 348 Times in 152 Posts
X2 on the HVH spacer - they make a killer piece, 4 hole transitioning into an open, my own preference is the 2" one, we have seen 31hp on the dyno on one occasion with only the addition of the 2" spacer - might have been a bit too small of a plenum added to the change, but 31 is still 31.
Phil Molski PMR Performance S/C 1623 |
Liked 308 Times in 103 Posts
Spacers are a trial and era part,I 've seen cases where they make 25,loses 25 ,or does nothing,it just depends on combo and how close plenum size is to what engine wants.
Mike Taylor 3601 |
Liked 13 Times in 9 Posts
x3 on the HVH Super Sucker.
Liked 6 Times in 4 Posts
x4 on the HVH Super Sucker.
I picked up 8 hp over a 1" open with a 1" HVH.... |
Liked 759 Times in 379 Posts
If it's a "super sucker type spacer aka blended spacer you want, the phenolic version available from Canton is a better piece than the plastic from hvh...
https://www.cantonracingproducts.com...CER-BLENDED-1/ That said, I have never seen any improvement on the time slip from any spacer on any car I've owned or tuned in the over 20 years I've been racing however I have used 1/2" phenolic or wood to isolate the carb from manifold heat. Further, many bracket cars are running a manifold with too much plenum volume for optimum performance and the addition of a spacer just makes it worse. Last edited by 1320racer; 08-01-2013 at 11:30 AM. |
