Old 08-03-2013, 11:49 AM   #1
Lyn Smith
Liked 1,002 Times in 203 Posts
Default Q Jet VS 4 GC
If you had a 327 Stocker motor with a Q jet,and you pulled off the Q jet and manifold and put on a 4459 intake and 4 gc how much would you slow down?
Old 08-03-2013, 01:47 PM   #2
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Default Re: Q Jet VS 4 GC
I dont think you would slow two much. Maybe 1 to 2.
Bob Bender 144 O/SA
Old 08-03-2013, 03:11 PM   #3
Dave Crouchet
Smile Re: Q Jet VS 4 GC
What combo in which car are u referring to Lyn. nova or chevelle?
The 327 459 250hp in a 65 chevelle will run 11.40s in k.
David Crouchet
Dave Crouchet is offline   Reply With Quote
Old 08-04-2013, 07:53 AM   #4
james schaechter
Liked 1,443 Times in 302 Posts
We have swapped engines from our Nova to the Chevelle before. The 327 275 is the same as the 65 327 250 hp. We just changed intake and manifold. If you factor the weight diff, it was about. 3 tenths slower, but the factor was better in the Chevelle. Same engine qualified better with the 4gc in the Chevelle. This was a few years back. It is all aboutnthe factor.
The 4gc is more forgiving with the fuel system, but slows down more when the air is bad due to its small cfm flow compared to the qjet.
James Schaechter 3163 STK
Old 08-04-2013, 10:30 AM   #5
Jim Hanig
Liked 99 Times in 49 Posts
I swapped A qjet with a 4g on the dyno this was on a 327 275 ss motor and it was 40hp ,i diddnt have a killer spacer for the 4gc.
