Old 08-06-2013, 05:30 PM   #1
Dyno
Dyno's Avatar
Liked 693 Times in 205 Posts
Default 305 Chev Sleeves?
Does anyone know of a sleeve you can use to down size a 350 block to a 305 bore. Part number would also help. thanks, Dyno
Old 08-06-2013, 05:41 PM   #2
JHeath
JHeath's Avatar
Liked 370 Times in 101 Posts
Default Re: 305 Chev Sleeves?
a 305 HEMI????
Jerry Heath
I/S '93 Cobra
FS/J 2010 Mustang "Ebay CJ"
Old 08-06-2013, 07:50 PM   #3
FINESPLINE
FINESPLINE's Avatar
You can try Darton as their site does mention custom sleeves. Might get costly but best to call.
FINESPLINE is offline   Reply With Quote
Old 08-06-2013, 08:09 PM   #4
JRyan
Liked 112 Times in 31 Posts
Dyno,
Much cheaper to sleeve a 307 Chev block. Some of them were cast on 350 cores.
Jerry
Old 08-07-2013, 08:44 AM   #5
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
If you want to sleeve 350 down to 305, I would look @ melling CSL283 is 3.800 bore which you could finish to 3.796 if you were going .060 or could go .070 or .080 CSL 283 is 1/8'' wall so OD should be where it will press into 4.050 hole w/ about .002 press.
As J Ryan said a 307 would be good choice also.
I had Darton make some custom sleeves years ago for 4 cyl. project,at that time you had to do a min. of 12 pieces I believe.
Mike Taylor 3601
Old 08-07-2013, 11:04 AM   #6
Tom Moock
Liked 10 Times in 6 Posts
Dyno, why don't you buy a small bore bowtie block? Tom
Tom Moock 5704 STK
Tom Moock is offline   Reply With Quote
Old 08-07-2013, 12:22 PM   #7
Dyno
Dyno's Avatar
Tom, I did not think they were still available. Anyone have the part number for that block? thanks.
Old 08-07-2013, 01:47 PM   #8
Mike Taylor 3601
Was'nt small bore version 3.875?
If buying new might check Dart they may make something,have seen them make some special blocks,had customer that got 2 solid Big M's,cast iron no water jackets,they had extra deck left if remember we were able to make 11.675 deck height.
Did move these without using overhead hoist.
Mike Taylor 3601
Old 08-07-2013, 02:31 PM   #9
LE WILSON
I have a new GM small bore bow-tie block. IT has a rough bore of 3.660 . Will make a 305 or 283. Guaranteed. Local pick-up in Ky. Will deliver to div 3 races. $1500. Contact Larry Wilson SS/L 3058 @ 502-262-3280.
LE WILSON is offline   Reply With Quote
Old 08-07-2013, 02:58 PM   #10
FED 387
Liked 333 Times in 180 Posts
look at GM part # 10051182 or 24502501 ---same block but last one is all CNC'd up--
FED387
