No matter how many good runs I have stored can't seem to predict that 1st run very well. Why is this ? Same track , same DA and weather almost identical , even using a couple programs for the prediction. Can't figure it out ?
Liked 9 Times in 3 Posts
The temp of the fluids? I always pick up a couple on the second run
Mark Markow 171 ss/tb |
Liked 20 Times in 12 Posts
What about getting it really hot before your first run. Leave the hood shut and let it gradually cool down some before your first run? I believe that it helps the engine and driveline get some head soak and warm the oil up some. I know there is limitations but it is worth a try. It has helped one of my cars be more predictable on the first run.
Liked 535 Times in 110 Posts
X2 You may not be warming the engine and driveline up enough prior to your first run.
Jim Kaekel 3836 STK |
Liked 13 Times in 9 Posts
Even warming it up on jackstands doesn't seem to work as well as making the first pass, from my experience anyway.
I think there maybe more factors involved besides oil and water temperature?? |
Liked 2 Times in 2 Posts
Put a temp gauge on the trans. Trans fluid temp will definately make a differance.
Get up on the converter in the staging lanes or get a magnetic pan heater. |
So you guys think temp is doing it ? I warm it up good through the pits but never got on the transbrake. Try to keep the water temp around 160-180 when I go in. I can`t get it any closer then within 20 deg. if that would make that much of a difference ? Thanks
You see cars driving down the return road to the end and back each morning at the races for a reason. I would not warm mine up on jack stands myself. I (and several others I encounter doing the same thing when I am) drive down the return road to the end, turn around, stop, set on the trans brake for ten seconds, and if the scales are open check my weight. The digital scales we have now don't vary much, but you never know. When I get back I plug in my cool down battery & charger until I get the engine back to ambient. Always runs the number first pass.
Ed Wright 4156 SS/JA |
Liked 228 Times in 70 Posts
Could possibly be spark plugs loaded up and maybe after making one pass it cleans them up?
I would think you would hear it miss. If tuned correctly, your plugs will always stay clean.
