#11 |
I got the one I have from Scoggin Dicky in Lubbock, TX.
Ed Wright 4156 SS/JA |
#12 |
Liked 308 Times in 103 Posts
Alot of cams are more aggressive,but the problem is the valve springs,it is'nt high spring pressures causing problems,it is too weak of springs that stretches your chain.
When pressure is high enough,once cam is rotating it turns easily,because you have one lobe pushing and one lobe pulling,so to speak,when spring pressure is too weak,lifters won't stay on lobes and you loose the smooth rotation and puts alot more strain on the chain. If you don't believe me adjust one rocker on high spring pressure engine and try to rotate engine,every rocker you adjust it gets easier,when all are set does'nt take very much to rotate engine,the faster it turns the easier it gets. As example we use at least 275lbs on sbc and at least 325 on bbc rollers this is on just common bracket engines not that aggressive of lobes. Mike Taylor 3601 |
#13 |
We've had great life out of our Cloyes sets on the stocker engines. Never a problem at all. We typically get several hundred passes out of them, and only replace them out of guilt. We use the set that has the 6 bolts on the cam gear to allow easy adjustment.
Nothing wrong with Rollmaster sets, either, good quality pieces. If you're killing a Cloyes race set with heat treated steel gears, you have something really bad going on. By the way, Kevin Cradduck, my partner, and the guy who runs NitroPlate, is a patent holding timing chain engineer. He'll tell you in a heart beat that chains do not stretch, the gears wear. If you ever saw what they use to pre-stretch a timing chain, you'd be pretty convinced that your engine simply won't stretch a chain. Usually when you have a timing set go away in a very short period of time, if it is a real race set with a good roller chain and heat treated steel gears, you have some serious harmonics that are doing it. At that point, the timing set is merely the fuse in the circuit, it gives up before something else breaks.
Alan Roehrich 212A G/S |
#14 |
Liked 974 Times in 310 Posts
Alan is correct the chain doesnt stretch. Did you check the alignment of cam and crank gear? That can wear gears quickly.
#15 |
Liked 89 Times in 28 Posts
If the chain doesn't stretch why does installing a new chain on the old gears make the slack disappear?
If the gears wear out wouldn't the new chain be sloppy as well? Sorry guys the chain might not stretch, but it definitely wears. Maybe it's the pin area on the chain that wears??? |
#16 |
Liked 68 Times in 26 Posts
hi, a question ? I assume you soak the chain in can of oil for some time before installing? I had chains stretch, before, since I soaked them in can of oil, they live a lot longer.
#17 |
Liked 205 Times in 93 Posts
31 hundred series from compcams for us here. trouble free and the price is right. not sure who manufactures them and we pre-lube a ton at install...
#18 |
Liked 535 Times in 110 Posts
I'm not disputing anyone but I've used Cloyes sets with success. I've replaced chains as well to take the excessive slack out as well and after I replaced them the slack was gone. A timing chain has what seems like a couple hundred links and pins, and if they all wear just a tiny bit, it surely will create some slack.
Jim Kaekel 3836 STK |
#19 |
Ok, I got it--chains dont stretch, they just get longer with use.
reed |
#20 |
Liked 759 Times in 379 Posts
As others have stated, Rollmaster which I have been using on my BBC since 2000.
That said, I have never broken a timing chain and typically go 2 full seasons, 500+ passes. Further, my current BBC makes nearly 950HP. |
