Old 08-10-2013, 06:17 PM   #21
CMcAllister
Liked 920 Times in 259 Posts
Default Re: Rear Suspension Video
Originally Posted by K Stubbs View Post
You definitely need an Anti Roll bar. This will eliminate the twist and keep one side from doing something different than the other.
Beat me to it. I agree. At one time I thought these were a band aid. Now I think they should be on most cars. Get one that's heavy enough to do the job.
Also, IMO 150# springs are way too heavy. Much like a six cylinder type spring on the front stores energy and helps the front suspension to separate and transfer weight, a light spring on the rear wound up a few inches also stores energy and helps get the rear out and applied at the hit. I prefer to use a light spring to accomplish that and use the shock to control the speed. 110s may be a bit too light once you raise the front of the bars, which I agree should be tried. Tightening the compression should help keep the rear out and applied and reduce the basketball effect of the tires. A rough racetrack may limit how tight you can run that knob. Also, I'm not sure a stiff sidewall tire is what you want. The stiffer sidewalls tend to want to bounce the rear back up into the car more so than other style tires.
Old 08-11-2013, 07:57 AM   #22
Bruce Schoenbaechler
as an old retired Superstock racer that ran a 283 I was wondering how you were setting your pre-load on your car. I set mine by having the car as level as possible and then adding enough weight in the front seat to equate to my own weight, then set the pre-load. I went through a few adjustments when I first got the car but after I got it set I didn't have to touch it, and the cars 60' was in the very low 1.40's.
SCHOENY
Bruce Schoenbaechler is offline   Reply With Quote
Old 08-14-2013, 07:38 PM   #23
Patric Fox
Patric Fox's Avatar
Liked 11 Times in 8 Posts
You might not want equal weight on the left and right rear tires. My friends ladder bar car required 30 to 50 more pounds on the right rear to leave straight.
Patric Fox is offline   Reply With Quote
Old 08-14-2013, 11:01 PM   #24
Jeff Lee
Jeff Lee's Avatar
You can also straighten out a car the leaves "slightly" left or right (typically it will be right) as simple as adding another 1/2 # of air to the slick. If it's pulling right, add air to the right slick.
Jeff Lee 7494 D/S '70 AMX
