Old 08-10-2013, 10:28 AM   #21
Stewart Way
Liked 70 Times in 22 Posts
Default Re: DP rear axle assembly
Jeff
I agree with everything you have written. The old techman in me is just trying to wrap my little brain around how this then applies to the rest of the Mopar fleet. It would seem that once the Strange9 was submitted on the TI and approved it then became "another from the same automobile manufacturer" as the rulebook requires to then be allowed for all Mopar stock racecars. Much the same as Mike described the Dana. Both built by an outside manufacturer and accepted in a car (Strange9) or cars (Dana) by NHRA and therefor would seem to be accepted in all Mopars as the Dana is. Again, where is my logic flawed?
Stewart Way 2424 SS
Old 08-10-2013, 10:34 AM   #22
GUMP
This issue needs to be clarrified by the NHRA in the published rules. When I started on my 2010 Camaro, I was told that I could not run the 9 inch. I have also been told that a 12-bolt would be OK in my COPO.
Old 08-10-2013, 11:29 AM   #23
Andys dad
Andys dad's Avatar
Liked 175 Times in 78 Posts
This is not rear axel related but since we are talking "years" --
Did MOPAR/NHRA authorize the lift off hood with a scoop to accommodate the 426
It did not come on the 2011 V10 Drag Pak
They must have ,,, LOL
So we cannot just swap out the V10 without changing the hood - could loose some weight
Ron
Old 08-10-2013, 04:26 PM   #24
Jeff Teuton
Liked 325 Times in 50 Posts
Nobody has any flawed thinking, but from NHRA, that is what is accepted. The 9" was specific to the V10 car and now also to the 426 car. NHRA has not accepted the 'any corporate' yet for the 9" in other cars. I was just presenting what I have from NHRA after a racer complained to me about the subject and I inquired. I would hate to see one of my fellow Stock racers show up and be turned away especially at Indy because of this item. It's a whole lot easier to address before you leave to go. Pretty simple.
Jeff Teuton 4022 STK
Old 08-11-2013, 09:03 AM   #25
SPS
Liked 3 Times in 2 Posts
I believe Mike has this completely correct.
Call it what you want, or what year you want, but the part number is there.
I realize Jeff's point but NHRA needs to get this right....whats good for the goose, is good for the gander. (my Dad would have said.)
Hell, the 8 3/4 is a 9" housing anyway! And I'm sure theres no advantage either way other that life.
A good lawyer 's letter (where's Cambria when we need him) would certainly straighten this out fast.
FJ
SPS is offline   Reply With Quote
Old 08-11-2013, 10:24 AM   #26
GUMP
I hear what you are saying, but Jeff is right. The NHRA, to this point, looks at the new (FX) cars differently. They really do need to publish a clarification.
Old 08-11-2013, 10:46 AM   #27
RJ Sledge
Liked 294 Times in 93 Posts
It was my understanding that all the "NEW" cars (Ford, Mopar and Chev) get to run the 9" Ford with either the cast iron or ALUMINUM case................
The old rule about replacing a Factory rear end with another Factory rear end that was listed in the Factory parts list is not allowable at present.
Strange had a Aluminum case for the 9" listed in the Ford parts list and it was accepted by NHRA for about 20 years, now the only cars that can run the aforementioned case are only cars that were available from the Factory with the Aluminium case.
So let me see if I can get this straight....As of now I can't run an Aluminum case in my Pre 2008 Stocker (9") because it was not available from the Factory, but a Post 2008 Non-FORD car can???
Yeah, makes perfect sense too me.
I am not changing my r/e case for Indy.
Luv ya Jeff!!
RJ
RJ Sledge is offline   Reply With Quote
Old 08-11-2013, 10:49 AM   #28
Wayne Kerr
Liked 26 Times in 11 Posts
I completely agree with MPR, but would like to add one clarification as I understand it:
The new cars (CJ DP COPO) fit into the "inclusion" rule at the beginning of the Stock rulebook correct?
Just because it was permitted on an "inclusion" car does not mean that it will be permitted on a non inclusion car.
For example: you cannot put a S9 COPO rear axle housing in your 1969 Camaro A/SA, nor can you put an aluminum center section in your 1968 Mustang.
See you at the races,
Wayne Kerr
Wayne Kerr is offline   Reply With Quote
Old 08-11-2013, 03:48 PM   #29
Jeff Teuton
The 2009 and 2010 DP's were never allowed a 9" rear. The 2011 512 was as it was standard, and the specs for the 2011 426 car have it as standard. Doesn't apply to Fords, Chevys, Hudsons, Kiaser-Fraser, Fiats, Volvos,Lexuses,and several others. It does, however, apply to the 37 Hupmobile with the aluminum Gen III Hemi. This is not Swamp Science. And RJ, nobody cares what you do, well maybe some other Texans. I mean really, if you don't like this, then show up with the 9", tell the tech person "Look under my car. I have a 9" Ford type rear axle assembly. That's ok Huh???" The 38 Hudson Fastback is ok but only in red. Geeeeeee. Try to help someone drowning and they want to tell you how to swim.
Old 08-11-2013, 05:34 PM   #30
Mack Reeves
Mack Reeves's Avatar
Liked 44 Times in 13 Posts
Mr Jeff, you can lead a horse to water but some will just not drink!! No matter how thirsty they are???
Mack Reeves
2377 STOCK & SUPER STOCK
