#11 |
Liked 89 Times in 28 Posts
Also there are braces that connect the upper and lower front mounts.
#12 |
Liked 251 Times in 51 Posts
Do you know who makes those Jody? Those are a solution also.
#5457 Curt Rees
Curt Rees 5457 SS |
#13 |
Liked 17 Times in 14 Posts
Dave Outten 2222 S/SS/SST/SG/HR 2021 S 1968 SS 1969 SR 1966 1990 Bracket |
#14 |
Dave,
Thanks for the information. That is the product I am looking for. #5457 Curt Rees
Curt Rees 5457 SS |
#15 |
Liked 7 Times in 7 Posts
Curt,
Which motor and class are you running? |
#16 |
I run a 283 with a PG. GT/MA. If I weighed what I should, I could run GT/LA.
The car is not tubbed and has the basic stock style suspension with a 9" tire. I am not going to change it because the car can run several different classes of stock with 138, 140 or 180 hp 307 Olds. Change the front to an '84 and it could also run the 305 Chevy. As long as I can run the # I am happy. Probably will go to a 3 speed trans next year, either a turbo or a metric. Unless I can get my old '66 Bel Air back, then it would be a whole new ballgame. Parts are odered. Control arms braces and new lower control arms. Just as well do it right! #5457 Curt Rees
Curt Rees 5457 SS |
#17 |
Liked 1,583 Times in 582 Posts
Curt,
I noticed you are running a 12-Bolt rear end. Has the 12-Bolt been modified or did you just bolted the rear end from another car? The upper mounts on a GM 12-Bolt have a different location to the rear ends used in G-Bodies. There are kits available for the 12-Bolt swap on G-Bodies from various companies such as UMI Performance and others. http://umiperformance.com/catalog/in...products_id=76 http://www.maliburacing.com/iceman/G...%20uppers.html http://www.maliburacing.com/tech_rearend_swaps.html http://www.baselinesuspensions.com/kits/chevy.htm |
#18 |
The 12 bolt was in the car when I purchased it. The only changes I did to it were the upper control arms and added a sway bar.
Everything installed the way it should. So any modifications were done before I bought it. It may well have been an aftermarket housing. I did not ask the previous owner. Thanks #5457 Curt Rees
Curt Rees 5457 SS |
#19 | |
The guru that you are, you were right on! The driver's side axle tube twisted in the housing. "Christine" will not be dancing anymore this year. The rear end is coming out and going to be completely rebuilt. I guess I will take the '96 Caprice LT 1 down to Thunder Valley and out to Oahe and run for a street trophy during the Midwest Class Racers show at both tracks coming up. At least I will get to run something! If it goes down the track, it will break, not a matter of if, but when! #5457 Curt Rees
Curt Rees 5457 SS |
#20 |
Liked 184 Times in 113 Posts
I use Dick Miller products.
Have the upper and lower arm Brace to prevent cracking the suspension joints. D |
