#21 | |
No prep is king |
#22 |
Liked 282 Times in 103 Posts
#23 |
Liked 2 Times in 1 Post
Thing is, if you weld them on, will you be able to get the headers on and off easy?
#24 |
Liked 68 Times in 26 Posts
how much weld will be required to please nhra tech? full welds or partial welds? this is nothing more than a rip off to the sportsman racer. mr lemon is lining his pockets, same as the diaper guy. at the racers expense!! enough is enough. those teathers don't need to be SFI approved. thats a crock!
#25 |
Liked 3 Times in 1 Post
I got an idea im working on useing aircraft grade stainless cable and
aircraft clamping system |
#26 |
Another thing, even if you do weld them they still might require you have the tethers. Or does the rule say if you weld them they aren't required?
#27 |
There is no SFI Foundation specifications or testing criteria for the tethers.
Therefore, I assume it is up to NHRA to approve any solution for compliance with the rule. A similar design to the one they offer can use an aerospace band clamp that meets Military Specification MS21920. There are several vendors for these clamps in various sizes: http://www.herberaircraft.com/pdf/Ot...20bulletin.PDF http://www.clampco.com/products/products.asp As regards to the cable and ends, they can also be procured from a few companies and it would require the swaging crimping tool and gauge. Some sources for the cable, ends and tools are as follows: http://www.mcfarlane-aviation.com/Pr...?CategoryID=47 http://www.aircraftspruce.com/catalo...ntrolcable.php For guidance on assembling, strength requirements and testing the cable, I suggest checking out the FAA Mechanics Handbook and read Section 2-41 of the handbook and on. The link for the handbook is as follows: http://www.faa.gov/regulations_polic...frame_vol1.pdf Additional specification, assembly and testing guidance can also be found at the following link: http://thecableconnection.com/cable-specification.html I believe if you document the cable assembly, show load testing that meets the FAA guidance and requirements as objective evidence, NHRA should approve it. Control cable assemblies are used in commercial and private aircraft in a daily basis and I do not believe the threshold is higher for retaining a header collector in the event it comes loose. They also claim a "Patent Pending", well the concept, system and design is not patentable. A patent search will show many of the same concepts and ideas with patents. Since it appears that Collector Tethers is a sponsor of this site, I do not know how long this message will last. Last edited by SSDiv6; 08-28-2013 at 12:59 AM. |
#28 |
Liked 520 Times in 132 Posts
No. Especially on a Chevy II
#29 |
hi, they claim , they have a patent or getting one. those take about 2 to 3 years to get. they are not givin out on a whim! they have to have a patent lawer do a search , then the patent process can begin. just sounds soo fishy!! nhra can let us make our own! we'd have to give them a kickback prob?
#30 | |
Liked 11 Times in 8 Posts
Joe Buchanan SS/BX 3117 |
