Old 09-03-2007, 01:58 PM   #1
Joe DeMarzo
Liked 121 Times in 11 Posts
Exclamation Chevrolet Big Block vs Little Block
How much does a chevy big block weight over a small block? Anyone swap and know the difference?
Thnaks
Joe DeMarzo 1317 STK
Old 09-03-2007, 02:12 PM   #2
Mark Lewis
Liked 208 Times in 45 Posts
Default Re: Chevrolet Big Block vs Little Block
Steel head for steel head about 100 lbs. Aluminum head big block vs steel head small block is about 15 lbs if I remember correctly.
Mark Lewis is offline   Reply With Quote
Old 09-03-2007, 02:39 PM   #3
FED 387
Liked 333 Times in 180 Posts
396/427 BBC weighs 685 iron head/ iron block/iron intake
454 about 675 iron/iron/iron
SBC chev about 575 iron/iron/iron---take about 40 pounds off for alum int manifold or 535
Old 09-04-2007, 08:00 AM   #4
Joe DeMarzo
Thank you
Old 09-04-2007, 10:53 AM   #5
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
When I converted my '67 Camaro from a Z-28 (D/S) to an SS w/396 375 (A/S), the car weighed 180 lbs more when finished. That was in 1985 so the engines used stock rods, cranks, pistons and iron water pumps. Consider SS hood with cast louvers, SS emblems and 396 emblems added, but removal of factory 4-piston disc brakes w/booster replaced by factory drum brakes. Additional bars were added to the roll bar and 2" x 2" .083" subframe connectors were welded in at the same time. Maybe some additional weight in the headers. All food for thought.
Old 09-04-2007, 11:53 AM   #6
Adger Smith
Liked 880 Times in 311 Posts
Dwight,
I did the disc brake change on my 69 Z-28 in 1970. I used all the front suspension on a 6 cylinder donor car. My old faded memory says it was 38 lbs different in the disc set up & that included the lighter idler arm, drag link,pittman arm & manual steering box from the 6 cyl. car.
Adger Smith (Former SS)
