#41 |
Liked 520 Times in 132 Posts
X2. Someone had to of said something for them to look.
#42 |
I guess if you have a 10,000hp Funny car you don't have to abide by this rule.
#43 |
Liked 44 Times in 13 Posts
That about says it all.......
Mack Reeves 2377 STOCK & SUPER STOCK |
#44 |
Liked 135 Times in 74 Posts
Carey, Nhra may be cracking down on transmission certified products. I believe there maybe a mandate out there right now to look hard at transmissions and certs. At the atco divisional recently a Super street racer failed tech for transmission sheild cert. Think about how hard it is to check the cert on a super street car, most are full body cars, and it would be very hard to check, but they did and car failed tech. There was also a instance of another 4 cylinder car in comp that had a adapter fail. So maybe they have decided to check real hard, hope they were not picking on you. and remember there are many things that sometimes do not make sense but you have to decide if you want to live by their rules or not.
#45 | |
Liked 6 Times in 5 Posts
#46 |
sounds as if NHRA wants Honda so provide pit scooters, ATV's and UTV's and maybe a few generators.
#47 | |
I'm all about safety, and had EVERY safety item needed to run the ET/MPH that my car runs. I had no problem doing everything they told me I had to do in that 3 day span (and the tech guy literally told me these were the 3 things I needed to do so I could race). I have no problem following rules either, but as posted above, everyone should be held to the same standard if they are going to enforce such a rule, and clearly they aren't. Also, rules need to evolve a bit. I'm going to be speaking with someone about this, because I feel this particular rule needs to be revised. Any suggestions from some of you guys that have been through this? Who would be the best person to talk too, etc.?? Thanks for all the support, it's actually quite overwhelming. All the messages, facebook posts and messages, visits by the pits, it's all much appreciated. |
#48 |
Liked 7 Times in 1 Post
I think folks are all thinking zebras and not horses in your plight Cary.
With Chevrolet on board sponsoring the event, the huge turnout of the big 3 factory cars, and your performance numbers from last years event; there was NO way a Honda was going to sit on the pole this year. So they clipped your wings before you could fly. I have so much respect for all of you guys who continue coming back after being sucker punched time and time again by the politics that have permeated this particular sanctioning body’s policies. JJ |
#49 | |
Liked 66 Times in 30 Posts
BTW Carey your S2000 is way cool! Last edited by Jeff Kempton; 09-03-2013 at 12:56 PM. Reason: Spelling |
#50 | |
With Skillman’s Ford being on of the big 3 manufactures my assertion holds a bit of water. Truth be told Jeff, they led this racer to believe if he followed their protocols he could race. He bent over backwards and did exactly what was required, If not an out and out conspiracy (as you stated being extreme) what then prejudiced the sanctioning body against this racer? |
