#51 | |
Liked 204 Times in 54 Posts
Just my .02. |
#52 |
You should have given them a tech card. They would have to write why they failed you on the tech card. When you fixed those listed items they would have to pass you. You gave them too many chances to pick you apart. It seems to me our cars have passed tech several times at points races, it shouldn't be a problem to pass tech at a national event. Sorry for your bad experience and hope it goes better in the future. Just another dumb Racer.
#53 | |
Liked 66 Times in 30 Posts
Carey has indicated that he wishes to take this formally up the NHRA ladder in search of answers, in a logical and factual way. I think that is the right approach, and may give him some closure on the incident and encourage him to continue racing with NHRA. He is definitely owed an explanation and hopefully an apology too. At the least the rules should be updated to keep this from happening again. Perhaps this was an individual inspector with a grudge that created this mess, or perhaps it even came from a higher ranked official. But the implication that there is a formal agenda to keep any high performing non-Chevys out of a Chevy sponsored race (or Mopar race, etc.) is pretty extreme. And to suggest that the entire sanctioning body is in collusion to stack the odds to make that happen is something that I just don't buy. If you truly think that the entire organization is so deeply corrupt why do you even race? Just my opinion; yours may be (likely is) different. You're entitled to yours, I'm entitled to mine. More importantly, I really hope that Carey gets the needed answers. I for one want to enjoy the sight of that S2000 racing in the future. Last edited by Jeff Kempton; 09-20-2013 at 12:22 PM. |
#54 | |
Liked 7 Times in 1 Post
#55 |
Liked 1,937 Times in 582 Posts
I don't think there was a conspiracy at all. The problem was he could not get the bell housing and the mid plate to conform to the rules as it is written. According to what is posted here the max space around the crank hub is 1 inch. He admits that his mid plate is cut to the outside dimension of the flywheel. Not all combinations can be run in specific classes with out major modifications. I think the car is really cool but really belongs in comp eliminator. Not really a super stock car in my opinion. I do wish him luck in getting a resolution to the issue. The bellhousing manufacturer should do the engineering and submit the fix to NHRA for approval.
Mike Pearson 2485 SS |
#56 |
Liked 135 Times in 74 Posts
carey is trying to race the car in Comp Eliminator now not super carey, you should speak with Browell on the chain of command at NHRA and who you should approach first. Browell has a bonus program in division 3 and alsois a big supporter of comp
#57 |
Liked 70 Times in 22 Posts
Carey
Looking at the picture you posted of the Funny Car, 2 things of note. There is a different rule for the space between the OD of the crank flange and the ID of the hole in the plate for a FC. FC has a limit of 7" max on the hole size, not the 1" difference. Can't tell what the ID is on the one in the photo. Second. if you look at the block plate/firewall it has a recessed area that the flywheel sits in that I think NHRA will likely tell you will be the solution to your problem. Think that piece has to be made by the same manuf as the shield. Just my thoughts and doesn't change the fact that you got hosed. Like most, I can appreciate the effort you have put in and hope you stick with it. As an old tech man, I can tell you one of the hardest things was telling someone that just because you passed last week doesn't mean you did this week. Doesn't sound like telling you was all that hard for the official you ran into. Just wondering, if you has turned in a tech card, what would you have done about dates on the shield and clutch?
Stewart Way 2424 SS |
#58 | |||
The hole around the crankshaft isn't cut to the outside dimension of the flywheel. Just enough to allow the radius on the back of the flywheel to meet the crankshaft. I would say the over diameter of the hole, if I had to guess, would be about 8" in diameter. I was entering the car in comp eliminator at this race. We made some changes that would bump us out of Super Stock. Quote:
I'm going to wait to approach NHRA and let the Indy buzz settle down, and for me to calm down even more. I want to approach this without emotion playing any role. And I'm still pretty bitter. ![]() |
#59 |
I was entering the car in comp eliminator at this race. We made some changes that would bump us out of Super Stock. Carey, Sorry I misread your description of the hole in the mid plate. I do wish you all of the luck in the world to get this issue resolved and good luck with your car in comp eliminator. I know the feeling when you get bounced for a tech issue. Happened to me at the Gators one year. No Fun. You just have to put it behind you and move on. You will get it!!
#60 |
Cary I have an idea for a fairly cheap fix to your problem. Atatch a round plate about 7 inches in diameter and very thin (.030 or so) to the crankshaft hub. This becomes part of the crank. so the flange is now 7 inches. So your 8 inch hole is rule book legal.
The 4 cylinder Chryslers use something like that (but the same size as the crank flange) that ataches to the outside of the flex plate to help prevent harmonics from shaking the flexplate bolts loose. I know how you feel I was furious that they made a big deal about the louvers in my fiberglass fenders. They allowed me to run that race but sent letters about me to all division tech directors so they would be on the lookout for me. I took off my fiberglass fenders replaced them with metal fenders that were 8 pounds lighter. And painted the whole nose with a rattle can. Telling me to change them would have been fine but the letters to all division offices was over the top.
Art Leong 2095 SS |
