Liked 5 Times in 3 Posts
dose anyone make one for a 307 olds? Perma cool has one that they say fits 95% of all engines...but goes on to say call tec to make sure it will work with your combo? if you've seen where the filter is on a 307 olds you would know why I want to move it.
Greg, put a small diameter filter on it. Short or long ones are available. Same as 301 Pontiac. PF 47 ,I think
"We are lucky we don't get as much Government as we pay for." Will Rogers Last edited by Mark Yacavone; 09-05-2007 at 05:45 AM. |
Liked 1,880 Times in 422 Posts
Try Trans-Dapt. I know I just put one on a Pontiac 455 for the exact same reason, and it worked fine. I used to run an Olds all the time, I tapped the holes in the block on mine, and used AN fittings.
Alan Roehrich 212A G/S |
Liked 333 Times in 180 Posts
Yep ---Trans Dapt part # 1420 I believe--Comp 387
Thanks guys! that thing sets so close to the header it has to be like having an oil heater!
Liked 101 Times in 27 Posts
careful on the remote oil filter-----I spent a fortune on plumbing and the best pieces available----after a few runs the bearings were gone, crank and rods got so hot they turned black-----went to a short filter after a rebuild. Just my humble experience.
