Old 09-15-2013, 06:33 PM   #1
SmBlkFord
Default Wheelspin or transbrake problem ?
Reaction times are in the teen`s - high twenties most of the time , especially when I am practicing a lot in car at home , Question is how can go from .012 ,.146 .055, .148 during a test n tune day with new slicks ? at first I thought it was some wheelspin , but how could the 60` times be within .011 from best to worst , This has been going on before and after car was re wired and its driving me nuts already , I hear the transbrake coming on and off , but the measurement in time is so small you would never know if it`s slacking , heard they just go bad and don`t work ? Have had this brake for years and trans has always been freshened , Thanks for the Help .
SmBlkFord is offline   Reply With Quote
Old 09-15-2013, 06:50 PM   #2
Curt Rees
Liked 251 Times in 51 Posts
Default Re: Wheelspin or transbrake problem ?
Tires are not slipping on the rims are they? Mark the tires at the valve stems and see if the marks move. I had that problem.
#5457
Curt Rees
Curt Rees 5457 SS
Curt Rees is offline   Reply With Quote
Old 09-15-2013, 06:55 PM   #3
SmBlkFord
Have rim screws both sides .
Old 09-15-2013, 07:47 PM   #4
Jody Lang
Liked 89 Times in 28 Posts
Sticky button or sticky valve that the trans brake solenoid activates?
Jody Lang is offline   Reply With Quote
Old 09-15-2013, 08:48 PM   #5
SmBlkFord
Button is good has been tested on a practice tree , solenoid maybe , what is this valve that you mean ? Is this part of the valvebody itself ? Thanks
Old 09-15-2013, 10:43 PM   #6
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Fix your trans its slipping !!
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 09-15-2013, 10:54 PM   #7
SS Engine Guy
If the trans has been out lately and you have an external transbrake solenoid it is very easy to bump it on the way in or out causing the plunger to bind slightly causing inconsistent releases. Also, a bur or foreign material on the internal valve that the transbrake releases on launch can cause these problems. I bumped so many solenoids in the past that I now remove the thing and plug the hole before removing a trans with external solenoid.
Just a suggestion. Most likely, as stated, the trans is slipping and new tires may have made it more noticeable.
SS Engine Guy is offline   Reply With Quote
Old 09-15-2013, 11:15 PM   #8
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Pressure regulator springs are often an overlooked source of consistency problems , especially on a fluid exhaust type of brake .
Brake valve release time is dependent on proper & consistent line pressure .
A low pressure problem will be even worse as fluid temp increases.
Old 09-15-2013, 11:48 PM   #9
Jody Lang
What trans is it?
No way trans is slipping if 60s are within .011. Could it?
Old 09-16-2013, 05:39 AM   #10
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
If possible,I would have somebody else drive the car and see what lights they get.Practicing a lot in car at home and actually being on a race track can be two different things.Try to eliminate the driver from the equation.
