Old 09-07-2013, 05:33 PM   #21
Jim Hanig
Liked 99 Times in 49 Posts
Default Re: 4gc carb
Originally Posted by Dean Oliver View Post
Jim,
Call me if you want to talk about this again. Have you tried everything we discussed previously? If this is a carb problem, we can solve it.
Dean
Dean what is a good time, the carb you did for me has weight on it, yes I tried the fuel pressure 10 10.5 11. 13. No help I have a 10 degree that is about 9 on the car this is a open spacer. Also a 7 tapered 1.75 , and have tryd 9 degree1inch open with the tapered 1.5 on top.None of these seam to make any change.? I have found a wedge float i will try next wk .
Old 09-16-2013, 12:51 AM   #22
Jim Hanig
Jim,
Dean
It was a gasket.Thanks to Gene B Who took the time to look it for me and came up with a fix. not the floats, not the fuel pressure, not a wedgespacer.
Old 09-16-2013, 05:32 AM   #23
james schaechter
Liked 1,443 Times in 302 Posts
Thanks for the update. Not very often do we get a cure posted. Was it a torn top gasket or?
James Schaechter 3163 STK
Old 09-17-2013, 10:00 AM   #24
Jim Hanig
There are 2 types of upper gaskets and for some reason this carb wants the closed one. Again thanks to Gene for his help.
