Old 09-27-2013, 10:45 AM   #21
Signman
Liked 269 Times in 99 Posts
Default Re: What Shifter do you run?
Turbo Action is a very good shifter
Not much to wear out or break.
Great with Power Glide.
Great with air and electric shifter.
Manual shift with 3 Speed Auto not all that good with certain shift pattern.
Precision Performance the finest shifter made.
Never miss a shift.
Works great shifting manually or air / electric
Takes a little getting used to.
Cost of the base model only a little higher than Turbo Action.
Have used Turbo Action with PG for many years with no problem.
With 3 Speed had trouble shifting 1st to 3rd. Not fun loosing rounds like that.
NO problems with Precision Performance Products shifter.
Old 09-27-2013, 12:09 PM   #22
Michael Compton
Liked 59 Times in 13 Posts
I posted previously about the PPP shifter.
I have had the Turbo Action, Hurst Quarter stick, and the PPP. All worked great but the PPP is some much easier to use. I have add all three in either electric, air or manual.
Unless you have used a PPP it is really hard to understand why so many people like it. Had I known early on how great the shifters are, I would have purchased one from the start.
Just my .02
Michael Compton is offline   Reply With Quote
Old 09-27-2013, 02:18 PM   #23
Ed Wright
Ed Wright's Avatar
Just my .02
I fully agree. I have had others too. Didn't what the big deal was until I bought one.
Ed Wright 4156 SS/JA
Old 09-27-2013, 02:33 PM   #24
Eric Merryfield
Eric Merryfield's Avatar
Liked 502 Times in 130 Posts
Cool Re: What Shifter do you run?
I have both PPP and Turboaction........for your straightforward reverse pattern the Turboaction is great for my Lil Red and Gremlin.....it also was fine with my 70 challenger....for a clean nuetral tranny like in the Dragpak the PPP is really nice, the Turbo action used with a clean nuetral tranny is touchy, and if you aren't careful you can do the 1-3 thing...used in the dakota.....it has a different faceplate, and works but it can be tricky... Long for stick of course..70 challenger..too bad they don't make one for a auto, that would be a best seller for sure.
I can't speak for non-mopar uses, or non-driver shifted uses...IE air shifted, electric shift......others can chime in.
Eric
Eric Merryfield 1883 STK
Old 09-27-2013, 02:34 PM   #25
Jim Kaekel
Liked 535 Times in 110 Posts
[QUOTE=Signman;401913]Turbo Action is a very good shifter
I had the same issues many years ago, shifting 1st to 3rd on occasion. I found that TA made a reverse shift specific gate plate which cured the problem.
Jim Kaekel 3836 STK
Old 09-27-2013, 03:18 PM   #26
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
3 speed, forward pattern, manually shifting 1-2 with the wheels in the air, every week, no trouble ever!
Old 09-27-2013, 03:50 PM   #27
jmcarter
jmcarter's Avatar
Liked 3,193 Times in 975 Posts
I've always used TA, Paul Forte pays contingency and stands behind his stuff. It's also nice to be able to just switch plates when going from 3 speed to PG and you can make it rear entry cable or front within 10 minutes. Understand Eric's point about easily getting to clean neutral but obviously not everyone is concerned about that anyway.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 09-27-2013, 04:23 PM   #28
gsa612
gsa612's Avatar
Liked 280 Times in 139 Posts
Turbo Action,3sp,fwd, I found you can't have a death grip on theT handle,if so you can go by 2nd into high, just slap it between 1-2 and it'll spring into the 2nd detent,works everytime.
Old 09-27-2013, 04:36 PM   #29
Mike Delahanty
Mike Delahanty's Avatar
Liked 276 Times in 54 Posts
Originally Posted by Paul Precht View Post
The stock push buttons, there's nothing better.
Me too. Max-Wedge Cars with push-buttons are cool. I get 2 very different reactions from people - those over 50 who grew up in the Muscle Car era just smile when they see the pushbuttons are still there - and the younger ones who stare inside the car for a while and then ask "where's your shifter?".
And I must say there is a little more skill involved in using your left hand to stab a button for the 1-2 shift just as you pass the 60 ft. clock - instead of having the E-Shift doing your work for you.
Old 09-27-2013, 05:34 PM   #30
Dion Hildebrandt
Dion Hildebrandt's Avatar
Just my .02
I too use the Triple P Shifter, they are great people to deal with. It is a shame their stuff is so good ,you rarely have to talk with them. Again had I known how good the product was I could have saved quite a bit of money....
Dion Hildebrandt 6009 STK H/SA
Dion Hildebrandt is offline   Reply With Quote
