Old 10-24-2013, 11:13 AM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Richmond Pro gear alert heads-up...
Documented last night on our car and confirmed from another Class racer in KY...the new 12-bolt Pro gears coming from Richmond have the pinion distance stamped incorrectly on the pinion head. First clue will be when checking the distance the numbers will call for about .230 shim lol.
Look for packaging labeled "Made in Italy". Seems Richmond moved their operations to Italy and the workers are having problems converting from their metric system. My guess is this is going to be expensive for Richmond as the problem surely extends further than just the 12-bolt versions.
Old 10-24-2013, 11:25 AM   #2
Ed Wright
Ed Wright's Avatar
Default Re: Richmond Pro gear alert heads-up...
Wow! Going to do it the old fashioned way, using the pattern. Going to make set up go a little slower.
Ed Wright 4156 SS/JA
Old 10-24-2013, 11:30 AM   #3
HandOverFist
My predictions are there are going to be a lot of "free" sets of gears flying out of Richmond shortly...major mistake...heads will roll.
Old 10-24-2013, 01:51 PM   #4
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Richmond was bought out by Motive at least a year ago and manufacturing was moved over seas.
Old 10-24-2013, 02:02 PM   #5
HandOverFist
The "Italian" stock just recently made it's debut...evidenced by the recent unavailability of gears through major vendors.
Old 10-25-2013, 12:26 AM   #6
ray sowers
Angry Re: Richmond Pro gear alert heads-up...
A few years ago I ran into the same problem with Richmond Pro gears, their gear cutting machine was setup wrong and I could not get the gear pattern anywhere right but
ran them one time. Called Richmond and talked with their engineer and he would send another set to Jeg's. Their pattern was dead on where it was supposed to be and are still running good some years later, I have the equipment and always do my own Ring and Pinion gears setup. Sorry to hear Richmond went offshore. BUMMER
ray sowers is offline   Reply With Quote
Old 10-25-2013, 08:47 AM   #7
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Can figure pinion depth using master housing dimension.
Measure pinion head thickness -(where bearing sets against pinion to back of pinion,same place you check center distance from) then subtract pinion head thickness from master housing dimension,that will give pinion depth checking distance.
Can't remember 12 bolt master dimension off top of my head,but you can find easy on line or richmond tech line etc.
Mike Taylor 3601
Old 10-25-2013, 10:46 AM   #8
ss wannabee
Liked 7 Times in 7 Posts
Getting tired of these moves and out-sourcing....HEY Motive....bring gear production
back to the USA!....WANT a "made in USA" product...in my Chevrolet race car!
American JOBS at stake!
ss wannabee is offline   Reply With Quote
Old 10-25-2013, 11:12 AM   #9
For the vast majority of OE 12 bolt housings, start with a 0.035" shim on the pinion. Odds are, you'll be within 0.005" of where you need to be. If you're taking a similar gear out, use the shim from the previous pinion, and you'll be within spitting distance.
The numbers they give you are the opinions of the guy running the Gleason machine they test the gears on. What matters is the pattern.
And yeah, unfortunately, Richmond hasn't been great lately, and Motive buying them is quite unlikely to improve that.
Old 10-25-2013, 11:34 AM   #10
Ed Wright
Ed Wright's Avatar
A rear pinion bearing honed out to a slip fit would be handy for finding the correct pattern. I've heard of them. I've never seen one.
