Liked 4 Times in 4 Posts
i have a 1968 mustang,428cj, pro shifted toploader, soft lock, cal tracs. i got out for the first time this year sunday, union grove. made 2 passes both passes the car made a move to the left after the 2-3 shift. the only thing that i changed was put a 1/2 turn more preload on the passenger side cal trac. i have looked over the suspension and nothing looks broke. any advice. thanks ron b
Liked 2 Times in 1 Post
If the front end settles down about the same time it could be bump steer. Derek
Derek Hake 4459 H/SA 69' Roadrunner |
i thought about that to. i have quite a few passes on the car and it usually goes pretty straight. weather permitting, i am going to set the cal tracs the same on both sides and go to the track sunday and see what happens. thanks ron b
#4 | |
Guest
Posts: n/a
I had the same issue. Started with preload, and it always drove to the right. We ended up setting the bars by adjusting the passenger side first and then the driver side. Ran ran a flat of preload in each bar and the car went straight.
#5 | |
Liked 4 Times in 3 Posts
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
thanks alex, i will give you a call around 11 tomorrow
