Liked 2 Times in 2 Posts
Which 1964 Plymouth body style would be better for stock eliminator, a hardtop or a post car and why? Thank you for any information you could share. I am finishing up a post car but I also have a hardtop I was thinking of converting to a stock eliminator car as well.
Fred Palumbo 1025 STK |
Liked 16 Times in 11 Posts
Fred, I always favored the post cars, I think they twist less than a hardtop.
Bob Pagano A/SA |
Thank you Bob for you answer.
I have a 64 Plymouth Savoy post car in poor shape body wise and I have a 64 Plymouth Belvedere hardtop in very good shape body wise and was wondering if it would be worth the extra cost to repair the rust and do the body work on the post car. The hardtop just needs some minor dings fixed and a repaint.
Liked 19 Times in 10 Posts
Depending on what type of rollbar or cage you're going to put in
would probably offset the stength advantage of the post car. Isn't John Shaul's car a hardtop? I can't remember I would use the better body as it will be stronger than a body that gets cut apart and has panels replaced.
Kevin Love 5666 STK/SS |
I don't know about the Mopars, but the Chevy II hardtop roof is an inch lower.
I'm not sure it makes any difference though..There are some very fast post cars out there.
Liked 2,487 Times in 698 Posts
I raced several 64 Plymouths in the 60s to 70s with Max Wedge
power. I believe the posts were slightly lighter which help when you could not adjust to class bottoms. With the cars tied and caged which I recommend I have seen no difference in stiffness or longevity. The Hardtop does look a little more Aero. When the car were not routinely tied and caged.......I did have flex problems behind Door sill area of Quarters. The sheetmetal deflected significantly in that area and truck seams seperated. I could Jack up the car and not be able to get the door open Last edited by GTX JOHN; 12-02-2013 at 04:40 AM. |
#7 | |
Art Leong 2095 SS |
Liked 693 Times in 205 Posts
Post cars looks like race cars, hardtops look like show cars.
Liked 354 Times in 120 Posts
On the HT chevy IIs there are renforcements in the roof to keep the doors closing right making it weight more, check your shipping weights between the two cars and see what your breaks are for your class that you want to run.
Tom Meyer 5240 SS Stock ??? |
Liked 13 Times in 4 Posts
Here is a good picture comparison of the two Chevy II models. Our post Chevy II doors didn't close right when the car was jacked up until we went with a cage and a sill plate bar (2nd pic) for additional support.
![]() sill post view ![]()
Joe Schaechter 3168 STK |
