Old 12-08-2013, 09:09 AM   #1
jeff keyuk
jeff keyuk's Avatar
Default Tires for your enclosed trailer ?
Best tires of choose for an enclosed Trailer .
jeff keyuk is offline   Reply With Quote
Old 12-08-2013, 10:39 AM   #2
james schaechter
Liked 1,432 Times in 299 Posts
Default Re: Tires for your enclosed trailer ?
Not sure about brands, but we switched rims to 16 inch from 15 on our 6 lug axles 24 ft trailer and they all lasted much better. Rims were steel and were only about 35 each. Worth considering if you are buying tires anyway.
James Schaechter 3163 STK
Old 12-08-2013, 11:51 AM   #3
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
I had numerous problems with trailer tires myself. 30 ft. 2 axle trailer. with 15'' tires.. why a trailer mfg. would even build it that way, I don't know ? so I also made the switched to 16'' wheels , and at that time I used firestone transforce commercial truck tires, instead of an st rated tire . plenty of load capacity and rated for more than 65 mph. it's been 2 years without a problem , where it used to be 2 or 3 blowouts every year. I'm sure any hd truck tire with enough load capacity would work, but I have had good luck with the firestone's.
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 12-08-2013, 11:59 AM   #4
Run to Rund
Liked 54 Times in 27 Posts
Maxxis probably have the best reputation and aren't from China unlike Goodyear Marathons, Tow Master, etc. Weigh each axle and side if needed to be sure the tire is not overloaded. In 2006 Goodyear put out a bulletin saying if you put in 10 spi more than needed for the load, you can go up to 75 mph. I assume this also means not inflating beyond the spec maximum, so the tire would be rated well above the load on it.
Old 12-08-2013, 12:04 PM   #5
cad
cad's Avatar
Liked 91 Times in 51 Posts
For a 15" tire, I have been using Towmaster D range @ $90 each. I am on my 4th set. I have never had a BLOW out. Right at about 4.5 years, I start running into a flat tire right after loading up at the races....then 1 every week or 2 after that. At that time, I replace all 4.
Again...never had a destructive blow out.
I do run them at max psi constantly and about 5 psi over max when running longer trips to Brainerd, Topeka, Kearney.
My trailer is loaded with a golf cart, jr dragster, tool box, coolers and my Camaro for a minimum of 26 race weekends per year.
I run the speed limit, which is 70-75mph, on the long runs.
I know where they are made, but that's what Joe Archer (here in Omaha) recommends for a 15".
Clark
Old 12-08-2013, 12:17 PM   #6
Painter
Liked 162 Times in 45 Posts
I have had a LOT of trailer tire problems with 15 inch load range "D" tires. Several brands, got the Goodyear bullitin about adding the ten extra pounds. After a LOT of research I found load range "E" 15 inch trailer tires. They have a little more capacity than the short 16 tires and have eliminated my problems.
Painter is offline   Reply With Quote
Old 12-08-2013, 04:33 PM   #7
340Cuda
Liked 801 Times in 338 Posts
Where did you find them?
Thanks,
Bill
Old 12-08-2013, 04:43 PM   #8
Painter
Several companies make them, I put Maxxis on this trailer. Carlisle and two or three other companies make Load Range E trailer tires.
Old 12-10-2013, 02:06 PM   #9
HolcombS/G155G
Jeff I've used the maxxis 10 ply tires. They're great. I've had them on my trailer for 4 yrs and have had no issues, They're about 130 a tire but worth it
DIV 1 Super Gas/Comp Newbie
2001 S/G Camaro, vfn bodied, all alum 430 SBC
2004 S/C Ed Quay XL 4 link dragster, 565 BBC
HolcombS/G155G is offline   Reply With Quote
Old 12-10-2013, 06:00 PM   #10
jeff keyuk
jeff keyuk's Avatar
Thanks guys for all the help ! I am going to go with Maxxis tires.
