Old 12-11-2013, 06:42 PM   #1
rod
Liked 20 Times in 15 Posts
Default tire speed rate ?
two years ago, I bought a pair of Remington tires for the front of my '56. I can not find a speed rating on them. these came from a warehouse which has a big turn-over, so they should not have been to old.
any ideas?
thanks Rod in AZ
rod is offline   Reply With Quote
Old 12-11-2013, 07:38 PM   #2
FED 387
Liked 333 Times in 180 Posts
Default Re: tire speed rate ?
Rod --look at TIRERACK.com-- they have a chart of speed ratings for those tires ---
Old 12-11-2013, 07:42 PM   #3
rod
I have that chart, it is that there is NO letter on the tire. unless it is in some of the small print.
Rod in AZ
Old 12-11-2013, 08:14 PM   #4
magnumv8
The standard has the "speed rating" letter in the actual tire size...
example....205/70SR-15.....the "s" is the speed rating in this case 112 mph.....a T is 118 ,H is 130, V is 150 and Z is over 150
If there is no letter in this position the tire technically has a rating below 100 mph........
This applies to radial street tires and not drag tires and the old bias plies didn't really have a speed rating per se.....
D L Rambo.....Stk 1300
magnumv8 is offline   Reply With Quote
Old 12-11-2013, 08:51 PM   #5
rod
100 is OK. now I wonder how much safety factor they build in to that rating?
racing 1/8 will never be a problem. and in the 1/4, I probably will get 105 mph.
more thoughts?
thanks Rod in AZ
Old 12-12-2013, 06:36 PM   #6
magnumv8
Keep an eye out for ozone cracking anywhere in the rubber of the tire....replace them if you see any....also never run a tire that has any repairs done to it, it's structural integrity has been compromised for any racing purposes.....
D L Rambo......Stk 1300
Old 12-15-2013, 12:57 PM   #7
chris ok
chris ok's Avatar
Liked 46 Times in 29 Posts
Remington in it's past was made by Dunlop. They were very similar to Dunlop Qualifiers. Remington had the XT 120.
They should be fine for what you are doing. We used them quite a bit when I was a kid.
chris ok is offline   Reply With Quote
