Old 12-24-2013, 10:19 PM   #11
ALMACK
ALMACK's Avatar
Liked 372 Times in 130 Posts
Default Re: 2011- 2014 V6 mustang allowed in stock
Thanks Tony.
Does the V-6 Mustang come with a 8.8 rear end ?
Sounds like the combo needs 4.56 (or higher) gears, 28 inch tall slicks, high stall convertor, and drag springs.
Would be great to get the car to run under the index with the factory 6 speed automatic.
P/SA & SS/PA Fox Thunderbird
I/PS '95 Mustang GT
Old 12-24-2013, 10:48 PM   #12
kdanner
kdanner's Avatar
Liked 38 Times in 17 Posts
They do have an 8.8.
4.56 with a 4.17 first gear? Good luck!
kdanner is offline   Reply With Quote
Old 12-24-2013, 11:53 PM   #13
ALMACK
ALMACK's Avatar
Is 4.17 the first gear ratio in the 6 spd auto ?
If so, 1st shift at 7500 rpm should be at 30-32 mph with a 28 inch slick..
I/PS '95 Mustang GT
Old 12-25-2013, 12:44 AM   #14
kdanner
kdanner's Avatar
Yes, this is why I had been running my 5.0 car with a 3.31 and 30" tire. Only uses 3 gears in a 1/4 and gets the overall ratio to something more manageable.
Old 12-26-2013, 11:42 AM   #15
efi v6
Al,
Kdanner is wright you have to watch what gear you run, my current tire is 28' tall I will be trying a 3.55 and a 3.73 maybe a 4.10 gear with both a 28' and a 29.5 tire just to see what it will gain. there is a lot to the tunes on these cars but it is all positive stuff ,will let you know how I make out !
Tony K.
efi v6 is offline   Reply With Quote
Old 12-26-2013, 03:16 PM   #16
novassdude
Liked 136 Times in 49 Posts
Glad to see it in the classification guide.
Too bad it was rated at 260 hp. Should have been 230 hp, IMO.
Isn't the factory rating on this 305hp? So they took off 45 hp and you wanted more? I wish I could have 45hp off my factory rating.
novassdude is offline   Reply With Quote
Old 12-26-2013, 07:51 PM   #17
Sean Marconette
Sean Marconette's Avatar
Liked 275 Times in 76 Posts
Exactly! We own a 2011 Mustang with the 3.7 and it is a very impressive engine. I don't understand the reduction if Ford advertised to the puplic 305 Hp, why is it derated by NHRA without it going down the track as a stocker yet?
Sean
Sean Marconette
84 Mustang
5060 SS/N
Sean Marconette is online now   Reply With Quote
Old 12-26-2013, 07:56 PM   #18
Ed Wright
Ed Wright's Avatar
Sean
Just more of the same. Ford sponsoring a race next year?
Ed Wright 4156 SS/JA
Old 12-29-2013, 02:40 PM   #19
efi v6
There are a lot of cars that are under rated at first ! but it does not matter for as the first guy that goes a second or more under things will start to change adjustments in HP rating, lower index etc. so with that said you have to be a fool to blast the index ! Me personally am happy with 4 to 8 tenths under. just my opinion and you know what they say about opinions !
Tony K.
Old 12-30-2013, 11:14 AM   #20
lstanford
Liked 134 Times in 32 Posts
Tony K.
Opinions are like noses everyone has at least one.
lstanford is offline   Reply With Quote
