Old 12-28-2013, 09:21 PM   #1
Alan Nyhus
Liked 799 Times in 236 Posts
Default Cam thrust button with hydraulic lifters?
What are the pros and cons of running a thrust button in a non-roller camshaft application? With the cam lobes having a 1.5-2 degree taper, it would seem that a thrust button wouldn't be needed.
Block is an early small block Chevy, not the later block with the cam thrust plate. Cam and crank gear are in perfect alignment (checked with the intake on and the distributor in).
Thanks! -Al
"That'll never work....."
Old 12-28-2013, 10:06 PM   #2
HP HUNTER
Liked 373 Times in 129 Posts
Default Re: Cam thrust button with hydraulic lifters?
Thanks! -Al
Has your cam tunnel been corrected? In a perfect world no button would be needed, look around whats going on........I would use the cam button, and always do on everything.
Old 12-28-2013, 11:40 PM   #3
carl hinkson
Liked 18 Times in 10 Posts
Thanks! -Al
Seeing the cam lobes are ground with a slight taper so the cam is always being pushed to the rear of the block.
Cam button is a waste of time and money. I have built a lot of circle track engines over the years and on flat tappet cams they need no cam button as I have never seen any issues not using one.
carl hinkson is offline   Reply With Quote
Old 12-29-2013, 11:28 AM   #4
Run to Rund
Liked 54 Times in 27 Posts
About 40 years ago Isky explained it. Many blocks have slightly crooked lifter bores, and with a roller lifter and cam, you can see the cam screwing itself into or out of the block when you turn it by hand, with the valvetrain assembled.
Old 12-29-2013, 02:20 PM   #5
gbur
Its all opinion,use your self guidance
gbur is offline   Reply With Quote
Old 12-29-2013, 04:16 PM   #6
BillK
Liked 30 Times in 17 Posts
Alan,
It cant hurt anything. If the cam does not move forward, then the button will just sit there. If the cam does move forward, the button will stop it
Personally I like the Teflon ones, real easy to "adjust" on the belt sander. I have seen a couple of the roller ones in pieces in engines I have taken apart, not worth the chance in my opinion.
Bill Koustenis
BillK is offline   Reply With Quote
Old 12-30-2013, 09:28 AM   #7
bob3240
Liked 16 Times in 5 Posts
Doesn't the distributor gear push on the camshaft because of the pressure required to drive the oil pump?
bob3240 is offline   Reply With Quote
Old 12-31-2013, 09:31 AM   #8
carl hinkson
Yes it does GM SBC and BBC has never used one with a flat tappet cam I would think they would know best.
