Liked 719 Times in 220 Posts
Who makes/sells a decent 12 volt trailer tongue jack that's not made elsewhere?(you know what I mean). Got a 20 foot enclosed tailer that needs a new jack. Thanks,racers.
Liked 18 Times in 7 Posts
etrailer.com has a number of jacks made in the GOOD OLD USA !
Liked 335 Times in 182 Posts
Atwood, Reese make them
Liked 28 Times in 15 Posts
Ultra-fab made the original jack on my 1992 trailer and I replaced it 2 years ago with the similar replacement. Ultra 3502 Check Website
bought on AMAZON - if I remember |
Liked 38 Times in 17 Posts
My Atwood has been holding up fine. If it fails I'll try an Equalizer, supposedly they are built like tanks.
http://equalizersystems.com/store/ho...s-capacity/tj/ |
Tuff tow-Ram-Atwood & others all about the same--get one with a light on it makes hooking the trailer up in the dark easier too---look on ebay- jacks starting at $100 free shipping and up--- a 2500 pound should work for you---remember to use a good quality and properly sized wire to power the jack---- this will cause it to not overheat and burn the motor out also make sure the battery is fully charged so the jack motor does not have to labor while operating causing premature motor failure---FED387
