Old 01-12-2014, 01:05 PM   #51
HP HUNTER
Liked 372 Times in 129 Posts
Default Re: Suspension help
Originally Posted by 1320racer View Post
Look to the best working GM A body stockers over the past 10+ years, cars like Kevin Bordstrom's B/SA '69 Chevelle and Jason Line's C/SA GS Buick and you find the answer to your question. It's ain't in the converter!
I would like to hear your take on this.
Old 01-12-2014, 01:08 PM   #52
philbilly
philbilly's Avatar
Originally Posted by HP HUNTER View Post
You need to test converters, and fine tune the converter, for optimum results. What gear stack do you run, and trans?
456 and its got a 200 metric.
philbilly is offline   Reply With Quote
Old 01-12-2014, 01:52 PM   #53
Phil, The dyno sheet will tell where the flash needs to be for optimum performance.
The stator configuration in the converter is what you need to be working on to get where you want to be for starting line RPM to get a good light.
Likewise with the front suspension raising up on the line .That's an inherent action due to the type of rear suspension used. There are work around solutions to control this, but they are not necessarily the best solution for the quickest ET, but rather to tune the reaction time.
Old 01-12-2014, 02:08 PM   #54
HP HUNTER
How much does your 8 inch converter weigh?
Old 01-12-2014, 02:30 PM   #55
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
THIS^^^^, nothing to do with the converter and the fix has been in use for over a decade and does NOT effect ET!
Old 01-12-2014, 02:55 PM   #56
16-18 lbs, depending on the application ( GM, Ford)
Old 01-12-2014, 03:01 PM   #57
1320racer
1320racer's Avatar
the spread is greater than 2 lbs. depending on the manufacturer but again nothing to do with philbilly's issue or it's fix.
Old 01-12-2014, 03:07 PM   #58
Ed Wright
Ed Wright's Avatar
My old Chevelle did that until I called Marv Ripes at A1. New converter stopped it.
Ed Wright 4156 SS/JA
Old 01-12-2014, 03:07 PM   #59
Ken,
What's that annoying, buzzing sound on this site? I thought you got rid of it a few months ago???
Old 01-12-2014, 03:14 PM   #60
1320racer
1320racer's Avatar
Mark, as a businessman you should refrain from those type of replys.
Ed as Mark has stated, the issue of the front suspension rising while coming up on the converter in a footbrake car is due to the type of suspension not the converter.
Again look to the best working GM A Body stockers over the last decade + and you won't see their front ends rising nor that of my former ride.
