Old 01-13-2014, 01:57 PM   #21
Ed Wright
Ed Wright's Avatar
Default Re: Are synthetic oils and lubricants any quicker
Ed -
I'm not sure it's much of an issue in a 12 bolt drag car. Circle track cars try to control the inertia that wants to move the lube to the right rear axle tube.
Jimmy said the 9" Ford rear does it on the bench. My MPH going up immediately after adding lube (and that/this gear set not wearing) made me think he was correct. If Jimmy told me a pizz-ant could pull a freight train I would start trying to figure out how to hook that little sucker up. :-)
Ed Wright 4156 SS/JA
Old 01-13-2014, 02:22 PM   #22
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
I know a Pro Stocker that uses a heater in his 9.5" housing. The cord is tied to the left wheelie bar, so is easily plugged in.
nothing trick here, many stock/super stock cars have this including mine.
Originally Posted by John Kissel View Post
There is a company called "Seals It" that makes all kinds of seals, including ones that designed to go into axle tubes like 9" Ford type rears to keep the oil in the center section and not go running into the axle tubes.
again nothing that isn't being used in many stock/super stock cars/rear housings including mine.
Old 01-13-2014, 06:41 PM   #23
Jimmy told me this several times, and I'm pretty sure he is correct. I wish I had tried it before we had that 5.00 gear in the 12 bolt go away. Jimmy said it does affect the 12 bolt as well. He also said to use API GL-6 lube. I tend to listen to Jimmy, I've known him since about 1980 or so, and every time I've ignored his advice, it has cost me, one way or another.
Old 01-13-2014, 06:48 PM   #24
Ed Wright
Ed Wright's Avatar
Thanks Alan.
Old 01-13-2014, 08:17 PM   #25
69Cobra
Liked 2 Times in 2 Posts
Question. If you put seals or baffles in the tubes to keep the lube at the gear do you need to worry about axle bearings?
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 01-13-2014, 08:25 PM   #26
Ed Wright
Ed Wright's Avatar
If your axle bearings are sealed, I wouldn't know why.
Old 01-13-2014, 09:03 PM   #27
69Cobra
been a long day lol.
Kris Rachford
C/S 3032
Old 01-13-2014, 10:31 PM   #28
Todd Boyer
Liked 6 Times in 5 Posts
Quite a few years ago, I read an article in a MuscleCar magazine in which they did a back to back comparison of regular and synthetic lubes in a '69 Hemi Charger with an A-833 4-speed and a Dana 60. IIRC the total difference between dinosaur oils and synthetics in engine/trans and axle was 3 tenths. Car went from 13.00 to 12.70 doing nothing but changing to synthetic lubes.
Old 01-13-2014, 11:38 PM   #29
Ed Wright
Ed Wright's Avatar
My p.o.s. didn't show anything when I switched.
Old 01-14-2014, 12:18 AM   #30
8secchevelle
Liked 6 Times in 2 Posts
Alan I had this conversation with mr. B about the gl6 lube but I have not been able to locate any , is it available in the Nashville area? Thanks .
8secchevelle is offline   Reply With Quote
