#41 |
He's back Alan. LOL
Ed Wright 4156 SS/JA |
#42 |
Liked 535 Times in 110 Posts
Jim Kaekel 3836 STK |
#43 | |
Liked 11 Times in 8 Posts
Joe Buchanan SS/BX 3117 |
#44 | ||
Liked 759 Times in 379 Posts
![]() I've stated in this thread that I typically got 200 passes on a set of gears in my former chevelle which btw, I'm told is about 100 more than a similar weight B/SA Stocker with a 12 bolt. I've also stated that I typically make 250 passes a season so one with a 3rd grade education could conclude that I changed the gears in my chevelle every season and I raced that car for 17 years but I only started doing them in '97 IIRC, after discovering they were broken after parking for the bracket finals. The Firebird is on it's 2nd set of gear since I have own it which btw, as of the last day of this season has over 200 passes on them! You absolutely infered I was lying! As to what you said Mark Williams doesn't recommend, again a legal disclaimer as with most if not all racing parts and again noted stock/super stock chassis builders have and continue to install aluminum spools in cars weighing in excess of 2800 lb.s without issue or concern. As for my truth and facts that you refuse to believe, call unbelieveable and refer to as a claim, how many of all those you've discussed this issue with over 30 years ![]() Last edited by 1320racer; 01-15-2014 at 01:30 PM. |
#45 |
Liked 116 Times in 27 Posts
How come every time 1320Racer posts, it turns into a "**** Show" and the thread becomes useless?...I was interested in this thread. Is it worth it to run a "Pro Stock" third members over "standard" type third members? what would be the average et gain, if that can be measured.
Richard Preiser 1613 FGT/I 1510 C/SA 161 F/DA Last edited by Rich67stang; 01-15-2014 at 01:41 PM. |
#46 |
I don't know, maybe it's because some here think that because they race stock/super stock they are smarter and more experienced than bracket racers no mind this bracket racer who runs a top shelf program and makes more passes every season than most stock/super stock racers.
#47 |
Liked 333 Times in 180 Posts
Now--- back to the original question-- Are synthetics any quicker or slower than other forms of rear gear lubes----- Do not care about gear life only results alsio I do not care about your technical expertise or lack of expertise WHAT WERE THE RESULTS ----Are they faster or slower and if so what were your results --Did you pick up or slow down??--Your experience please--No guesses or I think answers ONLYconcrete back to back results please!!!--Thank you FED387
#48 |
FED 387, please don't hold your breath on any actual reply from mr.1320 he has done everything BUT answer the question. Maybe when he's done blowing smoke up every ones wassu about how fast, reliable, and consistent his ride is.... Wait a moment, now it's 200 passes....well that's a bit less than 700 isn't it? BTW a recomendation from Mark Williams IS NOT A LEGAL DISCLAIMER.
Joe Buchanan SS/BX 3117 Last edited by buzzinhalfdozen; 01-15-2014 at 03:05 PM. |
#49 |
#50 |
Liked 13 Times in 11 Posts
HERE:
This should help everyone clam down. |
