#81 | |
Need to get me some of that lube. Thanks !! Btw, you don't have a 5.86 12 bolt Pro gear set for sale, do you?
Ed Wright 4156 SS/JA |
#82 | |
Liked 4 Times in 3 Posts
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net Last edited by Alex Denysenko; 01-20-2014 at 02:41 PM. |
#83 |
Thanks Alex! Yep, I ran 6.14 gears on the. '57 Olds/Pontiac rear end in my old C/SM Camaro. Old Zoom gears. Tried everything available for gear lube back then (mid/late '70s) to slow down wear on those few, small pinion teeth. My 5.57 gears last fine, I know a. 5.86 is likely to not last as long.
Thanks for getting back to me.
#84 |
Liked 805 Times in 245 Posts
Alex, when you say Joe Gibbs 'qualifier' gear lube, are you referring to the 70-80 weight?
For what it's worth (and not very scientific), put your hand on the rearend housing after making a typical single qualifying run in the morning, it is barely warm and probably cools right down after returning to the pits. On the other hand, try the same test after hot lapping 3 or more runs, you'll burn your hand doing the same test. Even at that, I doubt that the temp is all that high. Pretty obvious that that a typical drag race rearend seldom gets up to a reasonable operating temp. Jim Caughlin SS 6019 |
#85 |
Liked 354 Times in 120 Posts
Back in the day when VP was in oil business they made GL30-6 which was qualifying oil for nascar. This stuff is like water but it was a great gear oil. I put about around 400 runs on this stuff without any gear failure. Did not do a back to back myself but gave some to a friend who did. His car picked up .03 and 1/2 a mph. In ones search for speed you look for many small things that in the end add up to something bigger than what you had before. Tom
Tom Meyer 5240 SS Stock ??? |
#86 | |
http://www.drivenracingoil.com/dro/q...-gear-oilhtml/
Alex Denysenko NHRA 3038 SS, 3305 STK - IHRA 6 SS, 330A STK Moneymaker Racing LaPorte Indiana 219-861-1214 www.moneymakerracing.net |
#87 | |
http://www.slick50.com/index.php Last edited by Charlie A; 01-21-2014 at 09:45 AM. |
