Old 02-02-2014, 06:40 PM   #1
impstocker
impstocker's Avatar
Liked 53 Times in 16 Posts
Default 12 Bolt Backlash
Hello, going through my rear for the Impala, 12 Bolt w/ spool and 4:88 Pro Gears- what amount of backlash should I be looking for?
Thanks!
Will Lamprecht 65 Impala 396-325 I/SA in progress
Old 02-02-2014, 06:44 PM   #2
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: 12 Bolt Backlash
I look for .006 - .008 in our car.
Rich Taylor
I/SA - 321
Old 02-02-2014, 08:23 PM   #3
Liked 5,153 Times in 1,967 Posts
.005-.009 with automatic...tighter with stick
Old 02-03-2014, 10:03 AM   #4
Greg Reimer 7376
Liked 725 Times in 221 Posts
Cool Re: 12 Bolt Backlash
In all the 12 bolts I did, I tried to get .008" back lash,on a street application, as much as .010' is OK due to the fact that any heat soak can cause this spec to tighten up. I'm also assuming room temperature gears at the time of set up. Sometimes, the pro gears take different shims to arrive at the same spec as the street gears.
